Question about Alpine Car Audio & Video
I have an Alpine CDA-9815 head unit installed in a 2002 Dodge Dakota. I currently have a 12" DVC sub bridged at 4 Ohms. My head unit's volume goes up to 35. When i turn in past 24-25, the head unit resets itself. It completly powers down and comes back up. What is going on?
    President:
  • 624 Answers
It sounds like the sub woofer amplifier is pulling down the voltage level in the truck when it starts to get really loud. It may be the voltage regulator which is probably part of the alternator, or the alternator is not capable of supplying the needed current for the amplifier. If the voltage level drops below a certain level, the radio will see it as if the battery is disconnected. It requires a voltage level of around at least 10 volts to stay turned on. When an amplifier is playing loud, it draws a lot of current. If the current supply does not increase, it lowers the voltage level to compensate and get the current it needs to play at the level the head unit is pushing it to. As the voltage level goes down, the current increases when the voltage is dropping due to increased demand. You could check this with a voltage meter and monitor the level right at the battery and have somebody turn the volume up on the head unit slowly as you monitor the voltage level. The normal operating voltage of a car while the engine is running is about 14.4 volts. It should not drop much at all, no matter how loud the amplifier is playing. if it does drop, you have a problem with the trucks regulator or alternator.
I hope this helps, if you need more assistance let me know.
Dave
Posted on Jul 08, 2008
What is the best way to wire two kicker comp r 12' s to a two channel amp for max bass?
First, you need to know whether you have the 2 ohm DVC subs or 4 ohm DVC subs. Second, you need to know the minimum impedance the amp can handle (most are 2 ohm, some are less). Putting two voice coils in parallel will cut the total impedance in half (e.g. 2x 4 ohm voice coils in parallel = 2 ohms total). Putting subs in parallel will also cut the impedance in half.
At one end of the spectrum, you could put the 2 ohms DVCs in parallel, then parallel the two subs, and bridge the 2 channels of the amp. That would put 0.5 ohms impedance on the 1 bridge amp channel. If the amp can do 0.5 ohms x 1ch, do it. Otherwise, you may have to run the subs on separate channels.
Oct 23, 2015 | Kicker Car Audio & Video
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
How do i get my Alpine CDA 9885 head unit out to fit a sub???
Remove the face, and trimring plastic.
There are slots on either side that you put the Alpine unlocking keys into (came with your headunit new) then slide the chassis out.
If you don't have keys - you can use a small allen wrench - or buy them at best buy etc.
A local alpine dealer will probably let you borrow his keys as a good business practice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2009 | Alpine CDA-9885 CD Player
My subwoofer is cutting off. I replaced to fuse on the main power, and it works when I have the source on a very low volume level but when I turn the volume up, it cuts off. I have 1 alpine type R12 and a...
You are probably running the ohms too low for the amp and its drawing too much current. Consult your amp manual for proper load level capacity and you can wire it accordingly. More then likely its only 4ohm stable bridged and your running it at 2 or less depending on if your subs have single or dual voice coils. Try connecting one pos speaker terminal to the other speaker neg then run the left ofer pos on one speaker and the the left over neg directly to the amp (series) I will raise the ohms (amp makes less power) but should not cut off unless the subs ohm are still to low, if this is the case you need a sub with a higher ohm rating or an amp wiht a lower rating...
Nov 13, 2009 | Alpine SWR-1222D 12" Type-R Series...
Installing two amps
No, thats what you don't what to do. Even if you have 2 matching amps you don't do that. Every amp puts out different, and for 2 subs, you want to play at the the same time. If your only running 2 10's, I personal would just run the alpine (it's a mono amp made especially for subs) thats plenty for what you have. make sure you bridge them to get the full response. And your other amp i would use for your highs or mids, but run it @ stereo , which is 300 w @ 4 ohms. (Note: 600w @ 2ohms would be bridged and would play in Mono)
Building Competition stereo's is a big hobby of mine.
May 04, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Alpine CDA-9857 Volume Fluctuations
Please see my solution posted on Mar 13. No other brain waves yet!
Mar 13, 2008 | Alpine CDA-9857 CD Player
Understanding what the numbers are for
the numbers are frequency settings that filter unwanted freq.
theres is not wrong setting just play with it till your satisfied with the sound.
Nov 14, 2007 | Alpine CDA-9815 CD Player
Understanding the radio
equalizer highs and lows of sterio there should audio and entertainment buttons these should be your adjustment
you might need to upgrade the speakers for better quality sound sometimes these old speakers dont put out like everyone wants
Displays "CUR"
You probably have too low of an impedance load on ot (too many speakers or wrong kind). It has to have a minimum of 2 ohms on each channel, or 4 ohms if bridged (that means don't put 2 subs on the bridge!!).
Sep 22, 2007 | Alpine MRV-F345 Car Audio Amplifier
Car Audio & Video Logo
100 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
