The patch is a rough pointy patch sky blue in colour.Patch has got larger in time its always there i have changed the lamp but made no change to the patch. The TV is a LG rear projection monitor model MW-60SZ12 TV has done over 10000 hours. regards colin.
  • 4,889 Answers
I am so sorry to tell you that this is a problem with the optical block, usually the light tunnel. The entire optical block has to be replaced to resolve this problem and it is not cost effective(costs about 1200-1500$). You are probably better off purchasing a replacement tv, prefferably an LCD or LED tv as these are the most durable tvs in the market.
Posted on Jan 02, 2011
I have a xerox workcentre 7335 with the blue registration not alined with the other colors I replaced the blue developer housing and set up the color registration but it didn't help what can I do next
The problem comes from the trensfer belt. There is a silver patch on the belt that synchronizes the colours. This is probably dirty or detached from the belt. You need to clean the patch or replace the belt
Sep 16, 2014 | Xerox Workcentre 7335 All-in-one Laser...
Sway to right on rough road
I'm not sure that you have a problem. When tire adhesion varies from side to side, the vehicle stance will often change. In your described situation, the passenger tires have dramatically reduced adhesion and the drivers side do not. A bit of a sway to the right would be normal and expected. It's rather like only the drivers side wheels are moving the car.
Dec 12, 2013 | 2014 Subaru Forester
I have Simmons deep sleep air bed which got 2-3 leaks :( Suggest me something..what to do next?
If the holes are small, a dab of rubber cement on the holes may be sufficient to seal them. Larger holes will require a patch of the same or similar material as the mattress itself.
To properly adhere a patch, roughen up the mating surfaces of the mattress and the patch. Sandpaper is ideal. Be sure the mating surfaces are clean and free of dust. Apply rubber cement to the patch and apply it over the hold. Apply pressure to the patch using weights (a stack of books work great). Let the repair sit this way for the duration of the time required for the cement to set up according to the instructions on the cement.
Hope this helps.
Regards,
DIYpro
Apr 27, 2011 | Sport & Outdoor - Others
GREEN COLOUR IN PICTURE CENTRE
most likely the polarizers for the lcds have been burnt due to improper shutdown of the unit repeated times. Always use the remote or the power button on top to switch a projector off. never unplug or use the on/off switch on the back. this cuts ALL power to the unit, so if you have been using it for 5 hours and switch it off--guess what ? no fans to cool off the lcds or the lamp.
May 21, 2010 | Panasonic PT AE200 Multimedia Projector
Bright blue patch in center of screen.
The optical block is going bad. Contact Sony support and have your model and serial numbers handy. Sony sometimes warranties these even after the 1yr factory warranty.
May 16, 2009 | Sony KDF-42WE655 Television
Blue patch on screen KDF-42WE655
This is problem of Optic Block (light-engine) that will be replaced and it is costly fix.
Click HERE to get price info and part image.
May 07, 2009 | Sony KDF-42WE655 Television
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
Screen has developed several patches but only on blue images
drop it like its hot when your wife is away bang your dog
Aug 17, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
