Question about HP Office Equipment & Supplies
Edges of paper are printing with a yellow gradient. Is this a fuser issue?
  • 45 Answers
In these printer there is no fuser assembly. I thing the problem is of cartriage
Posted on Jan 01, 2011
There is a yellow edge on downside of paper when sent printing on the Lexmark x543. I have already tried changing the yellow ink cartridge. I have also printed the settings and the fuser, imaging ki
If it is pure yellow I would look at the yellow imaging unit (drum) to make sure that it is ok. That is likely the culprit if changing the toner did not resolve the problem.
Nov 07, 2014 | Lexmark X543dn All-In-One Laser Printer
Print smears on right edge of paper only
It is possible that the fuser film is damaged. The fuser film covers the heating element. Open the back panel, and examine the area where the paper exits. The grey film should cover the same area as the lower black roller. If not, you will either need to replace the fuser or obtain a replacement fuser film and install it. Is the printer noisier than it used to be? The fuser bushings on these printers are notorious for wearing out and causing the film to fail. If the bushings are worn then likely a replacement fuser will be the solution for you.
May 22, 2014 | HP LaserJet P3005n Printer
Keeps Jamming
It may be a Fuser problem:
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. if not then the fuser
Sep 24, 2009 | Brother MFC 7420 All-In-One Laser Printer
Media jam "fuser'
You need to clear any paper that is jammed inside. Then if you get the message after you clear the paper, check to see if it is a fuser problem.
Fuser problem:
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. if not then the fuser.
Here is the user guide, info is on page 89.
http://www.kn.nl/data/handleiding/174952/user%20guide_engels.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 04, 2009 | Konica Minolta magicolor 2430 DL Laser...
Jam in fuser even after replacement
Check your paper pickups. If they are worn and have problems picking up and feeding the paper, it might stop in the fuser. Check your tray settings, the paper guides and paper pickups. Straighten everything, and it should be all good..
Apr 07, 2009 | HP LaserJet 4600dn Color Printer
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Paper has black marks only on the edge
There are several issues that will cause a problem like that.
1, As X box mentioned is a problem with the drum. That is part of what is called the print cartridge or imaging unit. There is most likely a shutter or opening in the cartridge which you can shine a flash light at and see if the defect is visible. If so you will have to replace that cartridge. I would suspect that is the most likely issue.
2. There may be something in the paper path. A small piece of paper riped off in it, something else, a piece of tape, label, etc may have made it into the machine, that will make contact with the paper and smear the image.
3. Lastly, your fuser roller may be bad causing the reprint.
How to determine where the issue is, shut the machine off while it is printing and jam the paper in the image area. See if the defect is on the paper before the fuser. Eliminates the fuser ....
Feb 19, 2008 | Lexmark C522n Laser Printer
Misalignment messing up paper edge and printing
I would says check the fuser assembly for the folding the paper problem and the text tilting is a scanner/laser issue.
carefully check the paper path for anything blocking the way.
print a test page and open the lid when the paper is inside to stop it, inspect the paper to see if it's folded and also see the image on the paper to see if it's ok before reaching the fuser
hope this helps
Jan 04, 2008 | HP LaserJet 4p Printer
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
