Question about Western Digital 1TB My Book for Mac Hard Drive
My USB cable connection was pushed in and broke. It's detatched from the circut board it's connected too inside the hard drive. Can I buy this circut board seperately. It also has the power connector on it. I have the 1 tb My Book
    Scholar:
  • 149 Answers
No, but you can buy another enclosure to put your hard drive in. Disassemble your mybook, remove the drive and connect it to your new enclosure -- that's it!
You can buy a new enclosure from newegg, or radio shack (they had a few for really cheap on clearance last time I checked), Just make sure you buy the correct size enclosure, it's most likely 3.5"
Posted on Jan 01, 2011
What is the difference between a external hard
External hard drives contain a power supply to operate a standard hard drive in a case. It usually connects to a USB port. Usb drives get their power from the wire that connects it to the USB port A regular internal hard drive gets it's power from the computer's power supply wiring. The data cable is either a flat ribbon cable or a 6 pin cable that connects directly to the mother board.
Oct 15, 2014 | Computers & Internet
The piece that allows a usb cord to connect to the actual external hard drive broke off and i no longer can plug it into my computer. how do i get the piece out or fix it?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Or, buy an "empty" external disk-drive enclosure, for about $30, and "transplant" your disk-drive into this enclosure.
Nov 21, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Hi there, the metal connector for the usb cable has become detatched and is loose inside the HD. can anything be done to fix it?? thanx tony
Do you want to mean the connector of the firewire cable? As I checked specifications this hard drive is not equiped with USB connection. Every external hard drive's case can be disassembled, you can take a look here for an example. Anyway, if a metal part is inside the case you should somehow remove it to avoid a potential shortcircuit.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 07, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Green light wont stay on on memorex traveldrive
The light signals a connection between the hard disk inside the Traveldrive to its case. If it fails that means that the hard disk is dead. The unit has died, junk it and buy a new one, hard disks can't be repaired.
Aug 25, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have a SimpleTech 120GB external hard drive. The USB connection port at the circuit board is broken. Can I buy a new plug-in circuit board and hard case for this unit?
Simpletechs have a three year warranty so if your drive is newer than that it is covered. You can go to www.simpletech.com (they are really hitachi drives) for details on warranty repair. If you are sure its not covered the case can be opened and inside you will find a SATA drive and you can buy a new SATA external enclosure for 19.99 at Radioshack. This includes the circuit board, cable, and new case.
Jun 05, 2010 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
I need to know whats wrong with my driver side
Here is a website that a free manual can be down loaded for your vehicle
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 2002 Chevrolet Avalanche
External hard drive won't connect to computer
first of all you should try it on deferent pc , if its ok then thatleads us to insufficient power provided through usb ports , try usingback usb ports not the ON-front, and if the problem still try usingdual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.htmland if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changedif you cant find a similar one you may buy a new empty cage
Mar 22, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Usb broke off my seagate 320gb external
it does'nt really matter IDE or SATA both are using same connector. you can change it from second hand or from another board sometimes its not available.
Sep 02, 2009 | Western Digital 320GB MyBook External USB...
The port where I plug the cable coming from the computer to the external hard drive broke off the circuit board in the external hard drive. Can I fix it or get a repacement circuit board? Thanks
Your best bet would be to by a replacement enclosure. Online retailers like newegg.com can sell you one. Find out if your hard disk is SATA or IDE. You can then buy an appropriate external enclosure and move the hard drive inside your WD encloseure into the new one.
May 06, 2009 | Western Digital My Book Home Edition 500...
Usb connection on my attache maxfile broke. I still have the harddrive and need a new clamshell with usb plug.
You should be able to buy a USB enclosure from any well stocked independant computer store or online store, i.e. NewEgg or TigerDirect, to put that HDD in. I believe they are available for any standard or laptop IDE/SATA HDD. The enclosure should come with the cabling/connections to install the drive. If the drive is still functional, it should be "plug and play" once you put it into a new enclosure.
Dec 17, 2008 | PNY P-HD12GU20-RF MaxFile USB 2.0 Micro...
Western Digital 1TB My Book for Mac Hard Drive Logo
88 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
