Question about Vizio VBR120 Player
I have a vizio vbr120 blue ray player and want to use my onkyo universal remote but I cant find a code that works. The codes need to be 5 digits and start with a 3. I have found several that we thought would work, but nothing came of them. Does anyone have a code that worked and would you be willing to share that with me?
4 Suggested Answers
  • 13433 Answers
SOURCE: Using Vizio XRU9M universal remote. None of the
My name is Niko and I will be assisting you with this issue.
I see you where unable to find a working code for your blueray player. Please check this code list for codes that you may have not tried: http://www.vizio.com/documents/downloads/accessories/XRU9M/767Vizio%20XRU9M%20CL%202-25-10.pdf
If none of the codes work please try the code search feature of your remote.
Searching for Component Codes
If you cannot ?nd the manufacturer in the component list or the program code does not work, you can use the remote control to search for the correct component code.
To search for a component code:
1. Turn on the component.
2. Press the matching component button on the remote control (DVD, AUDIO, CABLE, or TV).
3. Press and hold the SET button until the LED ?ashes twice.
4. Press 9 9 1. The LED ?ashes twice.
5. Point the remote control at the component and then press and hold the POWER button until the component turns off.
Release the POWER button.
If the component does not respond correctly, repeat the search procedure to ?nd
another code.
Even thought the remote is a "universal remote" it is not perfect and will not work with every device out there, the remote contains a limited number of programmed codes in its memory and new codes to such a remote can not be added. So there is absolutely no guarantee that the remote would work with every device and the newest devices.
If you where to consider another remote I would recommend Logitech Harmony remotes which can be connected to a computer and have new codes loaded.
Thanks for using Fixya.
Niko
Posted on Jan 24, 2011
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
  • 4134 Answers
SOURCE: I have Vizio Blue Ray player and need a operators manual for the remote control. Where can I get manual for a VBR120 Vizio Blue Ray player remote control?
Try this....
Posted on Sep 21, 2014
Moved and lost my remote, but can't find a code in the Universal Remote booklet for this brand.
astar dvd 3100 remote code Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your astar dvd 3100 remote code question. Get free help, tips ... Ican't program the dvd to a universal ... dvd to a universal ... My VCD can play on DVD-3100 DVD player, but DVD disc can play on it. It always show "bad disc" ...
hd 3100 DVD & Blu-Ray Players Questions & Answers - Fixya
www.fixya.com > Forum > Tags > hd 3100
toshiba HD-A35 region unlock I am looking for an unlock code for the region ...nexxTech (EDP 3100) DVD Player Can't get my nexxTech (EDP 3100) DVD ... i need to find where i can buy a remote in b.c. canada i need a remote for my astar dvd ...My VCD can play on DVD-3100 DVD player, but DVD disc can play on it.
Lost Remote, Need Code For Universal Remote jx
www.hivmr.com/db/jx97xsd37ad83fd1mksxzxkf88ca3fa9
I recently moved and lost my DTV remote, I have a Phillips PM625S 7-device .....Need remote code for ASTAR tv's .... Need remote code for Sylvania Model 6719DF TV/DVD/VCR combo. ... DB:2.37:Remote Code For Vizio Vbr120 Blu-Ray Player 88 ...Would like to programme my SKY remote but can't find the code ...
Jan 18, 2016 | Astar DVD-3100 DVD Player
Universal remote code for a Vizio Blu-Ray Player
The universal remote brand will have it own unique code for Vizio.
Jul 14, 2014 | Vizio Vbr120 Blu-ray Player/ Internet Apps
Lost remote
Blu-Ray discs cannot be played properly without remote control. You must have its original remote control. No universal remote control will work with Blu-Ray. Contact the nearest Vizio authorised service center to buy an original one. Download the user manual to your player. Click here to download it. It will give you specifiction of the remote control.
May 27, 2012 | Vizio VBR120 Player
Can a Verizon remote be programmed for the vizio blue ray DVD model # vbr120?
No very likely as the remote has less than 60 possible infrared codes and likely does not have that one.
May 24, 2012 | Televison & Video
I am trying to figure out the code for my Philips CL034 Universal Remote to operate my new Vizio Blu Ray Player. I have tried every Vizio 4 digit remote code I can find. Plus, every 3 digit code with a 0...
You could try the manual code search for the remote. With the player on, press and hold Setup until the light blinks then press the button that you want to use to control the Blu-ray player. Press Play repeatedly until the player responds. Press and release Mute to lock in the code.
However, I suspect your problem is that the blu-ray player is newer than the remote. Universal remotes tend to be limited to codes for devices released 6 months or more before the remote was programmed. Thus you need a newer universal remote. You can try the remote that came with the Vizio player (most of these will control a few other devices).
I hope this helps.
Apr 04, 2011 | Televison & Video
Need Onkyo SR803 Remote code for Samsung BD-P1590
This should help you.
http://codesforuniversalremotes.com/samsung-blu-ray-player-remote-control-codes/
Dec 02, 2017 | Onkyo TX-SR705 Receiver
Need codes that will operate my ONKYO BLUE RAY DV-BD606 player
there is no sulution as far as codes are considered for blu rays. You have to do a manual learning mode for every button.you need to buy a learning remote this is where you point both remotes at each other and press each button to learn it. unfurtunately your sony remote does not have this funtion. i hope this clarifies your problem.
Jan 10, 2009 | Sony RM-V302 Remote Control
Cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
Nov 27, 2008 | Onkyo TX-SR605 Receiver
Vizio VBR120 Player Logo
215 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
