Question about Samsung S3500 Cell Phone
Battery is only 3 hours standing whats the problem
  • Samsung Master
  • 32,281 Answers
Ifthe battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Posted on Jan 01, 2011
I have a brand new laptop with an 8 hour battery that only last 3-4 hours. What all do I need to turn off?
Thank you for choosing FixYa!
Regarding this concern of yours with your battery, I would like you to understand that the 8hr time frame is basically the stand-by time for your computer turned ON but doing nothing. Now, if you base the battery's performance while you're using the machine, it can only run at most 4-6 hours depending on the application you are using, the resources that the application utilizes, and the running application required by the computer to run. It means that you really won't be able to max out your battery's 8hr capacity if you're using the computer on a regular basis.
The best practice though, is that you keep the battery reach at least 1% of power before charging the laptop to maintain and lengthen the battery's life.
Have a good one still. Take care!
Oct 03, 2016 | Computers & Internet
Chaging batter
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
When in standby how long should the battery on a J700 samsung mobile phone last before need to be recharged? Carphone warehouse says 48 hrs normal
Please find below official product information.
Battery Information Battery Life in Stand-by Mode 250 hours Battery Life in Talk Time 3 hours
Hope it helped.
Nov 26, 2009 | Samsung J700 Cellular Phone
Samsung sgh a707 battery problem his stand by time is only 3 hour and talk time is 30 min only
sounds like you need a new battery...also when you buy the new battery..make sure you charge it for a full 24 hours so that way it keeps it's memory and charges to it's fullest in the future charges.
Feb 11, 2009 | Cell Phones
Drains battery in 24 hours
THE BATTERS ARE DESIGNED TO WORK ON STAND BY FOR ABOUT 3 DAYS BUT THE MORE YOU USE IT THE FASTER IT DRAINS TALK TIME ABOUT 18 HOURES CHARGE EVEY NITE SHOULD SOLVE THE PROBLEM
Sep 18, 2008 | Motorola Mobility RAZR V3
Stand by time is about 12 hours
Couple possibilities:
1. Old battery: After a couple years of use, the battery simply can't hold a charge as well as it used to. If you are using an old battery, try getting a replacement.
2. Replaced battery with a NON-Brand name: If you replace the battery with a lesser expensive pack from china, they will typically use an inferior set of cells. Use only the name brand batteries for best performance.
3. You're in a location where you cannot pick up a DIGITAL signal. If you are roaming or unable to pick up a digital signal, the cell phone will constantly be searching for a tower wasting precious energy. For best standby times, make sure you are receiving a digital signal.
4. Battery charger malfunction: If you're accustomed to charging your battery with a wall charger, try charging it from your cigarette lighter in your car or with a different charger. If it works longer after doing this, drain the battery and charge again the way you usually do. If you're back down to only 12 hour stand-by, the usual charger may be malfunctioning.
5. Make sure your backlight is not on all the time. If your phone has a setting to keep the backlight on, turn it off.
Good Luck.
Apr 21, 2008 | HTC S620 Smartphone
Battery Problem
change handset battery and try.
Sep 25, 2007 | Nokia 6233 Cellular Phone
Samsung S3500 Cell Phone Logo
50 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
