Question about HP Pavilion dv6000z Notebook
How to connect wireless mouse the brand of mouse is intermec
    Scholar:
  • 149 Answers
Most wireless mice come with a dongle. If you have it, plug it in and let the driver software install (it should be automatic). If you have a CD, insert it and install the software. In order to pair the computer with the mouse, there may be a "Connect" button on the bottom of the mouse or on the receiver, press it to pair.
Some mice use bluetooth, which would require you to open "Bluetooth Settings" in the control panel, and use the "Add new device" wizard from there.
Posted on Jan 01, 2011
Can't connect CK31 to Barcode software
Hi Chris,
You need a few things to be able to connect your Intermec CK31 to a server and all the settings are within the "Intermec Settings" within the terminals control panel.
First thing to start with is the wireless profile, set this up to match your current access point wireless settings, SSID, Encryption Type, Key etc. You can also set your wireless IP. Once this is done there will be an icon in the taskbar that shows connection and signal strength. Depending on the firmware revision of the terminal you should be able to use the tools to ping a device on your network, if the server responds to a ping then you should be able to get to your server when you try and connect.
I hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jun 19, 2012 | Intermec CK31C,COLOR TE2000,5KY LINR
How do i connect my hp wireless mouse to the computer
The first step is to install its driver, after taht you can connect the wireless dongle into a free USB port of your computer, then put the batteries inside the mouse and turn it on, in the most of cases, the wireless dongle and mouse sinchronize automatically, if they don't, there's a small botton in both devices press it in each one to synchronize them manually.
Feb 25, 2011 | HP Wireless Optical Mouse
What is the intermec 2100 wireless access point used for?
Yes.
Get a spec sheet from here
http://www.barcoding.com/prodpages/Intermec/mlanap2100.pdf
Intermec's MobileLAN access 2100 offers the best in performance and range for Access Point technology. The 2100 is built to handle the demands of challenging industrial wireless networking while managing all your wireless LAN needs. Intermec's MobileLANaccess 2100 supports IEEE 802.11b High Rate WLI-F 2.4 GHz OpenAir 900 MHz Falcon and S-UHF radios. Long-range radio options and patented dual radio support help protect your investment for future migrations. Electronic software distribution simplifies system management. The 2100 offers HP OpenView WWWbrowser Telnet FTP DHCP(Client and Server) BootP and SNMP management options. Simplified software download capabilities. With the 2100 you have a wide selection of external antenna options least cost routing (maximizing bandwidth) and priority queues for superior overall performance in wireless access for your enterprise. The MobileLANaccess 2100 offers advanced network filtering and flooding features. Design the optimal network with Echo diagnostic protocol Client ARP transition for associated nodes and station parameter registration. Utilize the flexibility of broadcast-unicast flooding static and dynamic filtering and much more
Jul 15, 2010 | Intermec (2100D511704704) 802.11b Wireless...
My grandson removed the batteries from my Dell wireless mouse. I cant get the system to reconnect since.
Hi Dave,
Make sure that the batteries are the right way round in the mouse, if they are look under the mouse for the "connect" button and press that.
Go to the receiver and press the connect button on that also.
Once done just right click to activate the mouse.
Also make sure that the batteries are brand new.
Regards.
Aug 11, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Please how do i get to activate a toshiba wireless mouse
just connect the transiever(the usb part) to the USB port.normally it will be recognized automatically. If not you shoul install the drivers. Dont forget to put batteries in the mouse. After that you should set up the connection between the transciever and the mouse. in most wireless mice there is a deep button under the mouse or hidden in the battery compartment you should push it and then push the button on the transciever( in some cases in the opposite order; first the transcievers button then the mouses button). usually an LED indicates that the connection have succeeded( either on the mouse or the transiever )
LEDs condition:
flashing on/off not connected.
continuous ON means connected.
Hope it helps
BR
/BS
Feb 18, 2009 | Toshiba Satellite A135-S4527 Notebook
New Centrios wireless mouse won't work
. step 1. make sure batteries are charged and the receiver is connected in the USB port on your computer. 2. reset it with the reset button 3. IF there is a driver for it then go and Google centrios wireless mouse driver
Dec 30, 2008 | Computers & Internet
Intermec 751B problem after clean boot with iconnect
I had same problem with my Intermec CN3e after updating firmware OS. I also have updated the SSPB version (see it on intermec web site) and problem has been solved.
Nov 18, 2008 | Intermec 751 Barcode Scanner
HP Pavilion dv6000z Notebook Logo
99 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
