Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Im getting a Err 002 which means something is wrong with my CF. I have had it for 5 years and no problems until now. I tried to reformat but my camera will not let me into the menu option with the CF in and when I pull it out, it still wont let me reformat because there is not a CF installed. Can I reformat in a computer or do I need to get a new CF?
  • callie522 Jan 03, 2011
    Thank you for your reply, however it did not work. I reformatted in computer but when I go to put it in my camera still the same problem, ERROR 002 flashes and will not let me access anything on camera until I remove the CF card. I am going to go buy another card and see if that helps. Thank you again!
  • 747 Answers
I agree the problem is the CF card. I'd like to add that it must have several back to back corrupt files to be refusing formatting. As much as I teach/lecture not to do this I also agree that to save that card place it in a memory card reader and format the card in the computer. Check before hand to see if there are usable pictures and load them to a new file folder before formatting. Once formatting has been completed in the computer check that all pins are in correct and serviceable condition in the card reader slot in the camera before install it back into the camera. Then reformat the CF card in the camera. Each time pictures are downloaded to the computer a CF card should be formatted.
Deleting pictures just causes a huge amount of problems if done repeatedly in favor of formatting.
I'm including some diagrams to show where the formatting mode is located on your camera.
Best of luck
Hope this helps Happy New Year
Posted on Jan 01, 2011
99 error, CF memory card was removed to download pix. put CF card back in camera, but now get error message. removed battery and card several times, including replacing with another card. still get same...
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
Feb 13, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I have e05 message then an err 002 message, not sure how to fix. Is it possible the prongs are bent were the CF vard is input
Error 002 says memory card is full. Try to delete the card or reformat the card and observe
if camera wont allow to format the card. Try plugging it to a computer or laptop that hs Memory card slot and can read SD/MMC cards and format the card from the laptop
Jan 08, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel xt does not accept CF cards for no apparent reason
It sounds like a bent pin in the CF slot. This is not a do it yourself fix. Take it to a repair shop.
Jun 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 appears after every click for canon eos 30 D
Err 99, but lens-to-body problems are common- thought error 99 is a bit of a catch all- generally a lens and body conflict. And also Err 99 means that something wrong happened, but then it cleared out before it could be further determined.
Here is the blurb from canon to try:
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
For factory service, forward your digital camera (remove the CF card
and battery) properly packaged and insured, with a letter describing the
difficulties. Be sure to include your name, address, telephone number,
and proof of warranty (if applicable). Send to the Canon Factory
Service Center at the following address:
Canon Factory Service Center
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
Tel.# (949) 753-4200
Your equipment will be examined and you will be advised of the
findings.
The length of time for the repair will be dependent upon the nature of
the repair and availability of parts if needed. If the repair entails
something that is not covered in warranty you will be sent a written
estimate to the address that you have provided.
Please leave for me, a rating...
May 15, 2009 | Canon MF8180C Color Laser MFC Printer
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
XTI err need to replace CF card
Hi
First, if you can. Try and format the card a couple of times and see if this cures the problem. If not i would recomend getting the camera into a dealer to have this looked at. If all cards report the same problem this generally means it is an internal camera problem. The fault and repair of this can be varied hence the suggestion to visit an Authourised dealer.
Mar 24, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 & err cF in my canon 350d camera
had the same problem before
found this guide online
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Keep getting ERR99 when i take my first shot after switching on.
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
Jan 23, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
Feb 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
115 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
