Question about Car Audio & Video
Car CD stereo
I just installed a new car stereo player and everytime I turn the ignition it keeps resetting everything, What do I need to do
    Scholar:
  • 91 Answers
Either you blew the memory fuse or didn't connect the radio to the proper wire. Check fuses inside and under the hood.
The memory wire to the radio needs 12v all the time. If it's not connected or no power at the lead the radio will reset every time you turn off the car.
Posted on Jul 08, 2008
My 2008 sebring radio cd player keeps showing a comm error mwessage when turned on
You may have to have your stereo "matched" to your car. Your local dealer can usually do this for you
Sep 16, 2014 | 2008 Chrysler Sebring
Why do my settings reset in aftermarket stereo of my 92 mercury cougar
As well as the normal 12 volt line form the ignition switch, there is a 'permanently on' 12 volt lead, which keeps the clock and memories going even when the ignition is turned off. It sounds like the installer has missed connecting this one.
Aug 28, 2012 | Pioneer Audio Players & Recorders
I recently bought a JVC KD-R311 car stereo, its a great stereo but my settings dont save, for instance i set the perfect sound adjusting bass/treb/mid/loudness and whenever i turn my car back on after...
You need to have the yellow wire from the stereo connected to constant battery/12 volts. That wire supplies power for the memory, if it is connected to ignition power, when you turn off the car, the power for the memory is off also.
May 13, 2010 | JVC AM FM CD DET FACE CAR STEREO
Cd player stays on when you take the keys out of the ignition. how do i fix?
I assume you installed the CD player yourself?
There are 2 power connections to a typical CD player ...
* Battery (constant 12 volts to allow eject without key & keep memory etc.)
* Accessory (turns on radio when ignition is turned to acc or on)
The battery is typically a yellow wire and the accessory is typically a red wire. I'm assuming your installer has connected both directly to the battery cable (supplying power regardless of whether the car is on or not).
To fix the problem, you need to find the accessory cable in the car stereo group of wires.
I would usually use a tester to find which wires are 'live' when the accessory is turned on, then turn off accessory and re-test the live wires to see which one turns off when the key is off. This is your accessory wire and should be connected to the red cable of your car stereo.
Apr 15, 2010 | 2003 Dodge Durango
Car stereo JVC KD-PDR40 lost manual can't set clock?
hi my jvc kd-pdr40 cd player keeps resetting the sound to basic with no bass everytime i turn it off
Sep 26, 2009 | JVC KD-PDR30 CD Player
Car will not start after installing CD player into a 1999 Saturn!
Check your Ignition 1 & ignition 3 fuses in the inside fuse block,also check the body fuse 10amp in the inside fuse block.Keyless entry should take back off once you found the blown fuse.hope this helps
May 26, 2009 | 1999 Saturn SL
Getting the aftermarket stereo to keep memory
The YELLOW power wire needs to connected to an always ON fused 12v source.
Mar 13, 2009 | Panasonic CQ-DF203U CD Player
My Pioneer DEH-P4700MP keep resetting when car switched off
Did you use a harness to connect the wires?
Could be the power line (red) is connect to the ACC (Accessory) orange line, so every time you switch off the vehicle the power to the stereo is interrupted.
Sep 27, 2008 | Pioneer DEH-P4700MP CD Player
Everytime i turn my car off and take the key out of the ignition all my stereo presets reset. all connections made are correct, however there is one wire which is left over. it is orange with white stripes...
Most stereos have two power connections. One is "constant" (aka always connected to +12V) and the other is switched on/off by the ignition. They may go be various names. The idea is that the constant +12V keeps the stereo from losing all of the settings while the switched power turns the stereo off when the key is not on "start" or "accessory". It sounds like the both connections may be made to the switched power on your car, causing it to go completely powerless when your car is off.
Are the presets reset after you turn the car off or only after you turn your car back on? If they only reset after turning the car back on, it's possible the battery and/or electrical system is having trouble keeping the system voltage up while the starter is trying to turn the engine.
The illumination signal is usually used to let the stereo know when you've turned your headlights on, so it can dim the display automatically. Should be completely separate from your issue.
Apr 02, 2008 | Car Audio & Video
Store settings
make sure the red and yellow wires are not crossed over like they need to be for a vauxhall
Jun 02, 2007 | Alpine CDA-9853 CD Player
Car Audio & Video Logo
394 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
