Question about Kitchen Ranges
GE Electric Range Glass top....display does not work unless you turn a burner on. Shuts off as soon as you turn the burner off. Burner does not work however when you turn it on. Just the knob and "in use/hot surface" light comes on. Oven/bake doesnt work as well. So...we have a blank display that only works when you turn a burner knob on....however the burners and oven/bake doesnt work. Tried unplugging it for 30sec..nothing. Tried the breaker..nothing. no error codes. Can anybody help??? GE Model J BP80S0H3SS
    Master:
  • 604 Answers
Replace the switches
Posted on May 12, 2017
fridgetech
  • 473 Answers
SOURCE: burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Posted on Oct 09, 2007
  • 1314 Answers
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Posted on Jan 10, 2008
SOURCE: burner on range will not turn off
I am also having turn off problem on smaller burner of dual burner glass stove as of 8/2/08. It remains on high even when know is in off position.
Posted on Aug 03, 2008
  • 338 Answers
SOURCE: Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Posted on Nov 30, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
Kenmore glass top range left front large burner out
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
Burner temp.
If set to high, burners should remain on. If set to medium high let's say, they would be on for maybe 70 percent of the time, off for 30 percent of the time. If set to warm, they might be on only 10 percent of the time, off 90 percent. There is a high temp limiter which could turn a burner off. If you have a burner on high and are cooking on that burner and it goes off, the high temp limiter may be faulty. It is an integral part of the burner, and would require replacement of the offending burner. Burners are individually replaceable after lifting up the glass cook top.
Oct 19, 2008 | GE JBP66 Electric Kitchen Range
JBP75GS1WH 3 TOP BURNERS NOT WORKING
it could be bad connections at elements or bad elements a volt meter works good for this problem
Dec 10, 2007 | GE JBP60 Electric Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
