Question about Hotpoint Ovens
The bottem element in stove is burt out and i need direction on how to replace it
    Problem Solver:
  • 13 Answers
If you take the nameplate info to you supplier, you will be able to purchase a new element. Most manufacturers supply basic installation guides to help you. The nameplate is usually located on the left hand side of the drawer frame below the oven door, on the front of the appliance. If you still have further questions, this same nameplate info will help you on the manufacturers website. I hope this is helpful, Rob
Posted on Jan 01, 2011
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Defy 731 multifunction oven stopped working
switch as probably burt out so that the connecors inside dont touch anymore, or your supply fuses for the stove have blown, check your fuse box. but at any rate if there are sparks i would replace stove or get in a qualifed person the check your stove.
Oct 22, 2014 | Ovens
The stove is 26 years old. Has been working very well. Now the two heating elements on the left side of the stove and oven are not working. The pilot lights come on. Fuses in good shape and 220 volts...
check the contact points on the rear of the element they burn off after years of use, if the contacts are still good, Look at the element itself for any white marks on the element, if you see any , the element itself has probably burned out and need replacing , to get to the contacts,, depending on the oven, remove the back they should be right in sight , if you do need to replace the fittings on the wire ends, be sure and get heat range connectors
May 29, 2011 | Ovens
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
Hi.
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Regards.
Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
The lower element in my Admiral Sentry stove is not working. there is no layout for fuses so not sure what fuse needs replaced
It is not a fuse issue. Turn off the power to the oven. Remove the screws from the lower element. Pull the element out carefully. DIsconnect the wires. Take a volt/ohm meter set for ohms or continuity. Touch the 2 leads from the meter to the 2 element wire terminals. If you get no reading,replace the element with a new element.
If you do get a reading reinstall the element and replace the oven control.
Sep 21, 2009 | Stoves 720EF Electric Double Oven
Kenmore oven not working
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
Hope this helps
Vic
May 08, 2009 | Ovens
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Nov 26, 2007 | Equipex PZ-330 Electric Single Oven
Ovens Logo
41 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
