Question about Sylvania G-Netbook
I cant access my wireless connection with my slyvania netbook in my home. the set up described by the manual included does not come up when u choose wifi option. a website said to make sure external wifi switch is on position. does that mean there is a switch on the netbook itself?
  • 23 Answers
There should be a little slider switch on the side of the netbook.
Posted on Jan 01, 2011
Cannot accress WiFi on Sylvania SYBET7WIC-BK-Z
The Sylvania Netbook is an inexpensive 7-inch device that is convenient for accessing the Internet on public or private Wi-Fi networks. It is not intended to replace a regular computer for daily tasks; its purpose is to provide a lightweight unit to access social media and perform small tasks. The netbook defaults to mobile websites, but it does a good job at what it is intended to do. Connecting to Wi-Fi networks with your Sylvania Netbook requires configuring the device properly.
Boot up the Sylvania Netbook by pushing the manual switch below the screen. Push the F9 key to turn on the Wi-Fi on the device. Select the little wireless icon in the toolbar at the bottom; it looks like a small computer. Choose the "Wireless Information" tab. This will show the online status of the device, as in whether it has connected to the Internet. If you have checked the box beside this option, this tab also notifies you when new networks are available. If the status shows that you have connected. You may need to add your wireless router manually in the setup. Do this by choosing, "Add New." Obtain the necessary setup information from your wireless Internet provider. If you have an encrypted network, you will need to fill in that information about your router. To configure the wireless setup further, click on the name of the wireless network. Click on "Advanced Settings" and adjust your connection choices; this tab determines the order of connection if there is more than one network available. Another important setting on this tab is the "Allow Windows to configure my wireless settings" option. Check that box. Click the "Internet Explorer" icon on the desktop. If you are online, you will pull up the Google homepage. Hope this helps.
Dec 27, 2012 | Sylvania Synet7wic-bk-z2 Netbook
Cant get wii hooked up to wireless internet
hi
The Wii game console from Nintendo can connect to the Internet over a broadband connection for a variety of experiences, including: Web browsing, downloads, on-line chat and visiting virtually any on-line site including Flash 7 and 8 sites. The easiest way to connect to the Internet is to use your existing wireless high speed connection.
1Be sure that your Internet connection is running smoothly and the green lights are all up. If you have a Nintendo Wi-Fi connector, you need to have the software installed and your computer connected to the Internet.
2 Turn on your Wii.
Select Wii Options, which is located on the bottom left of the screen. This is the button with the Wii logo
4 Select Wii Settings.
5 Click forward to the second menu screen using the blue arrow to the right.
6 Select Internet.
7 Select Connection Settings.
8 Choose an open connection, indicated by the word: "none".
9 Choose a wireless connection.
10 Determine the best option for you: Manual configuration or Search for an Access Point.
11 On Search for an Access Point, your Wii will search for a wireless network to connect to and will display a list of available networks. Networks identified with a closed padlock require authentication to join.
12 Select your network.
    • If your connection signal appears yellow or red, the stability or strength of the connection is not strong enough for the Wii's Internet needs. If possible, remove any obstacles between the Wii console and the Access Point or change the channel on your router to avoid interference.
    • If your wireless access point does not show up when you choose, Search for An Access Point, your router may have Broadcasting set to "No" or "Disable." Some routers also refer to this security as "Stealth" mode. You can either change your broadcast setting to "Yes" or "Enable," or you can manually enter the SSID in the manual setup screen of your Wii console.
  1. 13Select Save and OK.
  2. 14Select OK on the next screen and the Wii will preform an automatic connection test.
  3. 15Wait for the Wii to connect and download any needed updates.
Dec 11, 2011 | Nintendo Wii Console
I recently replaced my old Belkin N150 Wireless Router with a new Cisco E3200 Wireless Router. After doing so, all of my wireless devices work (9 total) EXCEPT for my (2) Acer Aspire One Netbooks. The...
Remove and recreate the wireless network connection
  1. Click on Start, and then Control Panel
  2. Double click on Network Connections
  3. Right-click the wireless network connection, and click Properties
  4. Click the Wireless Networks tab
  5. Under Preferred networks, click the wireless network, and then click Remove
  6. Click View Wireless Networks
  7. Under Network Tasks, click Refresh Network List
  8. Under Choose a wireless network, click the wireless network that you want to connect to, and then click Connect
In Windows, there is a power mode setting for the wireless driver that may help this issue. Follow the instructions below.
  1. Go to Control Panel, System, click the Hardware tab and select Device Manager.
  2. Click the + next to Network Adapters and double click on the wireless network adapter.
  3. Click on the Advanced tab, select Power Save Mode from the list on the left.
  4. Change the Value on the right to Off.
    The default setting is Maximum, which may cause issues similar to those described.
Check to see if this has resolved the connectivity issue. If it has not, the following steps may need to be completed.
  1. Click on Start, Settings, Control Panel
  2. Double click Network Connections
  3. Right-click your wireless network connection, and click Properties
  5. Under Preferred networks, click the wireless network, and click Properties
  6. Click the Authentication tab, click to clear the "Enable IEEE 802.1X authentication for this network" check box, and then click OK twice.
Sep 23, 2011 | Acer Aspire 5100 Notebook
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have the Slyvania 7"
make sure you click on your network name, not another nearby neighbors.
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Dec 31, 2010 | Sylvania G-Netbook
I can't get online on my slyvania netbook can anyone tell me how..
If your trying to get on the internet with a wireless connection.and running WINDOWS,(many problems with LINUX) .and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (unplug for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Dec 29, 2010 | Computers & Internet
Slyvania netbook won't connect to wifi, it sees the wireless router, other devices (e.g. laptops and iphones) connect--but the netwook will not
Having the exact same problem....my daughters tablet can see our router, but it will not connect. any luck yet?
Dec 27, 2010 | Sylvania G-Netbook
Cant connect to wireless away from home
You have to manually connect to your University's wireless connection. Double 9maybe single) click the wireless icon bottom right screen and then untick the box for connect automatically under your home connection. Then double click on the wireless connection that you would like to connect to from the list of available wireless networks.
Jan 31, 2010 | Advent Netbook
My ausus eee pc series netbook wont connect to the internet what can ido ?
OK - I just went through 2 hours of madness to finally get this going on mine as well - here's what you need to do.
1. Go to your router settings (security) and if you have WEP enabled, change that to WPA (this is a better security anyway)
Follow this - step by step:
2. double click on your wireless icon (lower right corner of windows) - this will open up the "Wireless Network Connection Status"
3. click "View Wireless Networks" - you'll see all available
4. on the menu items to the left, click on "Change Advanced Settings"
5. pops up the Wireless Network Connection Properties window
6. Click Wireless Networks tab
7. click on your home network, or whichever one you normally connect to
8. when it's highlighted, click "Properties"
9. Make sure that the WEP is NOT selected, and select WPA
10. when you go to connect, it will again ask for your credentials - enter it, it should start checking acquiring network address...and you should get connected.
By the way, I tried updating drivers - restarting, moving closer, blah blah - waste of time. Changing the protocol from WEP to WPA did the trick, but remember you have to do it on the router AND your netbook.
if this helps, shoot me a "positive" on the feedback!!
on your netbook, go into your "view wireless networks" - choose the one that you normally use, for example, your home wireless network
Oct 26, 2009 | ASUS Computers & Internet
Wifi connectin problem
is your wireless router set to broadcast itself?
you should be able to double-click the small, single computer icon in the lower right corner and have at least one wireless network (yours) to connect to. once you click it to connect, it may require a key sequence, if it is set up for it (passcode).Also, try clicking "Start", right-click "Computer", choose "Properties", "hardware" tab, and "Device Manager". Check to see if your wireless network card has a driver problem (yellow exclamation point". Can you access the network with your netbook connected to the router via a cable? If you can, and have internet access, go to the Acer Support site and download the latest wireless card drivers and install them. see if this helps. Good luck!
Apr 30, 2009 | Acer Aspire One PC Notebook
Sylvania G-Netbook Logo
154 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
