Question about Philips Electronics - Others
What year was the Philips stereo recordergram RF770 made?
Philips model #24PT6341/37 Is this TV capable of switching from mono to stereo??
Its a stereo TV. And there is nothing to do to make it mono/stereo.If yo get stereo transmission then it will automatically change to stereo and vice versa.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 11, 2016 | Philips Televison & Video
I need user manual for philips stereo 4408.
Click the link below > choose the location and language > Type in your TV model number (as it appears on the TV) or Navigate through images
http://www.p4c.philips.com/
May 04, 2014 | Philips Reel To Reel Stereo N4408
Is there some way to connect an ipod to a Philips mc-m570 stereo?
the interface will probably only work with the phillips software, but many of those stereos support playing from a flash drive.
Oct 20, 2011 | Philips MCM570 CD Shelf System
How to connect philips shd8900 HiFi wireless headphones to an 5.1 amplifier
Look at the manual.
http://download.p4c.philips.com/files/s/shd8900_10/shd8900_10_dfu_eng.pdf
It only accepts stereo input. Your unnamed 5.1 system will determine what it has for headphone or Line Level stereo outputs.
Aug 13, 2011 | Philips Audio Players & Recorders
No stereo signal from FM? I have had this receiver for several years. I have tried several times to get a stereo FM signal. I have tried a "T" shaped antenna, an "S" shaped antenna...
Appears that your multiplex circuit in receiver is fubar. Also make sure that your receiver is set to the Stereo mode since the mono mode will also turn off the tuner stereo section.
Jun 17, 2017 | Pioneer VSX-D811S Receiver
Philips MCW770/37 stereo will not power on any longer.
Hi ,
This is just a suggestion. Check your speaker wires at the back and at the speakers. A shorted speaker wire will cause a tripped breaker.
May 19, 2010 | Philips MCW770 CD Shelf System
What year is the recordergram rf4
1965...I worked at the Hendon SA factory at this time actually on this model. BTW you'll find a date code on components such as IF transformers. For example, 12x5 indicates twelfth week of 1965, the time the component was produced, usually approx. 5-6 weeks before the radio itself. Hope this helps..
Nov 23, 2009 | Philips Electronics - Others
How to Connect Converter to TV, DVD/VCR and a Stereo?
Connect converter box to your DVD/VCR player at the ant in. Depending on your location you might need a new ant for UHF.
Jun 15, 2009 | Philips DVDR3435V/37 DVD Recorder/VCR
Electronics - Others Logo
67 people viewed this question
Top Philips Electronics - Others Experts
Electro Med Services...
Bill Boyd
Are you a Philips Electronics - Other Expert? Answer questions, earn points and help others
