Question about Elna 2005 Mechanical Sewing Machine
I've borrowed an old elna machine and I used it fine a year ago, but this year I've forgotten how to thread it and how the bobbin threading works as well. Could you please help?
    Genius:
  • 1,788 Answers
Go to www.sewusa.com and you can see threading of different machines. You can buy a manual from them also. You tube shows how to thread machines also. Good luck
Posted on Jan 01, 2011
  • Tally Girl
    Tally Girl Jul 14, 2011
    How did you go with your vintage Elna. If you are not familiar with the Swiss Elnas, the following may help you.
    Early models would have red dots for oiling points, usually one in the middle of the bobbin holder, and often another red dot nearby in the race area. Plus a couple on the body area sometimes or top of the machine. If this model has red dots, then definitely give each dot a drop of good quality clear sewing machine oil when you get the machine out to sew, especially into the bobbin holder, then run the machine slowly without a bobbin or thread for a few seconds to spread the oil through the moving parts. Also brush out the bobbin holder area with a little brush first.
    Also, use Elna bobbins only, they are very distinctive and only have holes on the top smooth underside. Wind the bobbin with holes on top and load it into bobbin holder same way; this way you always have the thread onto the bobbin flowing in the right direction. And always Click the bobbin thread into the tension spring on the outside of the bobbin holder, there is usually an audible sound as you get it into tension.
    Lastly, HOLD the two threads at the back of the needle plate when you start a seam, to keep them clear of getting pulled back into the bobbin race. Always good practice and saves little jams happening.
    The Swiss Elnas are beautifully made machines and there are many loyal owners of 40+ year old machines out there still sewing away - Yahoo has a user group called "Elna Heirlooms" where many fellow Swiss Elnas swap info, you may wish to join up.
How do i thread Elna 1200 also bobbin placement.
You should probably find an owners manual. Search for:
Make Model manual
(however, Elna manuals are seldom free)
IMPORTANT TIPS:
ALWAYS RAISE the presser foot when threading the top thread! Install a brand new needle at least every 8 hrs of sewing or whenever it strikes something. AVOID old and bargain bin threads.
How To Thread An Old Elna Sewing Machine
Elna Threading Instructions
Nov 17, 2017 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread from the bobbin is not getting looped
If the bobbin case rotates freely it is probable that the pinion gear is broken. Replace the gear, retime machine and voila it works again. Trouble is tough to find the gear anymore good luck it is a good machine and worth the effort
Jan 09, 2014 | Elna Sewing Machines
My very old little elna lotus (not sure if zz or sp) has suddenly jammed solid with the needle down through a piece of material. I can't move the flywheel at tall and I can't free the materia
Try unscrewing the needle, and then pull up the plate, and sort outthe threads very carefully with a quikunpick. When starting to sew, have slightly longer threads, make sure they are behind the needle, and hold them in your left hand. Especially when sewing very fine fabric, start slowly until you are sure the threads are forming properly, then it's OK to speed up. Use your ears, if it doesn't sound right, stop immediately. If you are going to use fine slippery fabric, be sure to do a trial piece first, rather than muck up your project. Elna machines are lovely to use, I've had one for over 40 years, still in daily use. Oiled with one spot of oil each time I use it, fluff regularly cleaned from underneath with the little brush supplied.
Apr 15, 2013 | Elna Sewing Machines
I have an elna airelectronic tsp machine & cannot thread bobbin. Please help
Firstly, have you got an Elna metal bobbin? it should be solid on the bottom and have 7 holes on top. It is essential that you always use it this way, wind it with the holes on top and load it into the bobbin holder the same way.
Have a look at the image above, you need to load the bobbin in and click the thread into the tension spring so it doesn't lift back out when you pull the thread upwards. There should be an audible click as it goes in.
If you can't get it right or this image is just too small, feel free to email me and I'll send you the image and talk you through it, I have a TSP machine too. cwrogers@tpg.com.au.
Also, check my tip on bobbin winding here http://www.fixya.com/support/r10598580-winding_bobbin_correctly it is important to get a good even tension onto your bobbin as you wind the thread on, you may need to manually add some tension to the thread as it winds off the spool, as I've described in my tip. I sold these machines for Elna and customers would bring them in complaining of problems with their machine. Almost aways, it was the needle in backwards, bobbin upside down, thread/lint buildup in the bobbin race or badly wound bobbin that was the problem.
Hope this helps you Gaylene, but if not, please email, I may be able to send you the relevant manual pages.
Apr 20, 2012 | Elna Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
Needle thread tension- huge loops
Put the tension settings back to the mfg's suggested setting.
Re-thread the machine with the presser foot up and there will be no more loops.
Mar 03, 2010 | Elna Sewing Machines
I have a old old elna Stella 27 and it's a beauty but I am having problems with the lower thread tangling until it is a thickish mass around the outer side of the place the bobbin goes, but then sometimes...
Hi! Congratulations on your old Elna! I just love old sewing machines; they are so solid and reliable.
(Unless of course you're getting a big bird's nest with the bobbin thread, right? That's so frustrating!)
With my old machines, I've found that a tiny bit of thread caught in the bobbin assembly can cause these nasty tangles. I use a bright flashlight and a pair of tweezers and just keep looking until I find it. While you're in there, clean out any old lint or gunk (meaning, old oil) you find. Brush all the lint out. I use a q-tip moistened with a bit of WD-40 to clean the gunk (but be careful that the fuzz from the q-tip doesn't come off while you're cleaning). With the WD-40, you have to be very careful not to get any of it on the surface of the machine--it can mess up some of those beautiful old finishes.
So clean the bobbin area, make sure you're threading the bobbin correctly, and lastly, if you hold the tails of the top and bobbin threads snugly in your left hand behind the needle while you take the first few stitches, the birds' nests should be a thing of the past.
Let me know if this works, ok?
Happy Sewing!
Feb 10, 2010 | Elna 2007 Mechanical Sewing Machine
Elna 2005 Mechanical Sewing Machine Logo
258 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
