How do I clean the mould out of the air conditioner
  • 784 Answers
Sometimes you can vacume it out -- use the brush attachment, if this does not get it all out you may need to use a air compressor to blow out all the debris and then finish clean up with the vacume.
c...
Posted on Jan 01, 2011
I have a magicool convair which is smelling a bit like mould how can I solve this
Check the control box there is connecting cables are safe or somthi burnt out
Jul 19, 2016 | Convair Heating & Cooling
VY commodore smelly air conditioner
Probably a build up of grime, mould, cigarette smoke(if you smoke in the car)_ etc etc. The air intake is under the passenger side. On some models , there is a filter that can be removed and cleaned, you would have to check with your Owners manual or a Dealer. There are cans of air con deodorisers available from Air conditioner parts stores (Actrol, Heatcraft , Airfridge etc) Spray the can into the air inlet of the air con whilst running. It kills anything bad and cleans and sterilises the air con. These cans are about $45 to $50 each, but they work better than unloading a can of Glen 20.
Sep 09, 2013 | Cars & Trucks
Musty smell coning from window ac unit
You can spray glen 20 or similar into the return air filter with the unit running to kill the mould that is causing the smell, the other thing you can do is runn the unit on "fan only" mode for 20 mins after it has been in cooling mode before you turn it off. This dries the evaporator coil.
Sep 06, 2012 | Frigidaire Heating & Cooling
How can i remove the fan barrel from the head unit to clean it
with care. first remove the screws holding the covers, you will find them behind two or three small caps near the louvers and maybe under the filter cover. Completely remove the plastic face. Remove the screws holding the coil in place. You can only remove the left hand end as the right hand is connected to the pipework. remove the grub screw holding the fan barrel onto the motor shaft. Remove the screws holding the left hand bearing in place. At this point you should be able to withdraw the fan barrel. Take very real care how you handle the coil, for if you kink the pipes your machine will no longer perform without some major surgery. While the unit is dismantled , try cleaning inside the machine, removing dust and mould. Reassemble in reverse order
Mar 05, 2011 | Fujitsu 12C1 Air Conditioner
When the air conditioner is running we get a rotten egg smell in the rv.
It is probable that you have a dead animal, ie: mouse in the system or maybe, moisture overtime has developed into mould under the face plate. I suggest some investigation behind the covers.
Mar 01, 2011 | Dometic Rooftop RV Air Conditioner
I have mould inside my LG inverter Air conditioner. How can I remove this?
use demestos water and a paint brush and use a stabbing action to clean coil
Mar 12, 2010 | Heating & Cooling
Fan roller and grey fins clogged with dust and mould
You can clean Blower wheel one of two ways. !st would be to remove the wheel and clean with the garden hose or if that is not a option for you then you can buy a can of compressed air and clean it that way but you will get a blast of dust and dirt when unit turns on. Make sure unit and/or power is of when doing this. Keeping your filter mainteneced more often will reduce the build up more.
Feb 15, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Bosch conditioner drawer
This problem is caused by the compartment not filling up sufficiently to start the siphon action. First ensure that the drawer is clean, especially the siphon tube then, with the drawer removed, check the top of the compartment. You will find various holes that let in the water, make sure these are clean and not blocked with mould. Clean out with mould remover and wire then run a cycle with no washing or softener/detergent in the machine.
Aug 01, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Kenmore 73259 wall unit a/c blowing out black particles
remove the filter aand run it and see what happens, the filter still could be causing the issue
Apr 25, 2008 | Kenmore 73259 Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
