Question about Philips Televison & Video
I have a philips universal remote but i am tryin to set it up to work on my SET BOX(IPTV) dont have any codes but i use TORNADO M10 codes!!!! please if someone could help me!thank you in advance!
IrishDruid
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
  • 11 Answers
SOURCE: Universal remote codes for Philco digital to analog converter box
http://www.remotecodelist.com/remotes/
Posted on Dec 12, 2008
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Posted on May 26, 2009
the q guy
  • 393 Answers
SOURCE: Universal Remote used to control Digital converter box
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on Jun 12, 2009
SOURCE: i have a philips universal remote code-cl043 and
I just move and lost my code sheet for my phillips universal control is there some where i can get some codes,i have a emmerson television thanks.
Posted on Oct 02, 2010
My remote has a "cc" button but nothing happens when I press it
Please add a comment with the source of the video content that you are watching. Also are you using the TV's original remote or a universal remote? The CC button usually will only work for OTA content and some cable channels (no set-top box). If your source comes through a set-top box, you'll need to access the captions from that source. (On some, you may need to access the Settings menu. On my IPTV box, it's in the Audio settings.)
If you are getting OTA content and are using a universal remote, the code that works for most functions may not give the correct signal when you press the CC button. In that case, you can try another code. For universal remotes with a learning function, if the original remote is available, try teaching the universal remote the CC function.
I hope this helps.
Jan 30, 2017 | Televison & Video
My universal Philips remote dont have a "code search"button' or a "set-up button,what can I do
The subject header says it does and all the Philips remotes I am familiar with have it.
Jun 07, 2014 | Philips PM-4S Maganvox 4 Device Universal...
I need the idigital rm-810 universal remote codes for **** smith set top box
Hi, I do not have the codes for it. Most likely you will have to get an original remote for you smith set top box to work it. I do not believe a universal will work with your unit.
Oct 23, 2011 | Philips Magnavox Learning Universal Remote
Tryin to program remote and cant find the instruction
I NEED HELP WITH A PHILPIS UNIVERSAL REMOTE......TRYING TO PROMGRAM IT WITH ESA TV
Sep 15, 2009 | Philips Magnavox Learning Universal Remote
Jun 12, 2009 | Philips PMDVD6 Remote Control
Need a code
Try here
Hope this helps!
-Curtis
Rate my solution please!
Jan 30, 2009 | Philips Universal PH301S Remote Control
Remote control won't work
Try here
Hope this helps!!
-Curtis
Jan 28, 2009 | Philips Universal PH301S Remote Control
Regarding your remote control, Philips Magnavox PMDVD6 - universal remote control, below is a link to to the user's manual for this and a couple other remotes that share this model number. Click below, choose your remote and the click the PDF user's manual. In the search box, type in the word, "code" and all things pertaining to setting a code will be displayed each time you press enter.
I hope this helps!
- CBR2009
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?submit.y=16&scy=US&submit.x=18&searchtxt=PMDVD6&ctn=PMDVD6&slg=AEN
Aug 07, 2008 | Philips Magnavox Learning Universal Remote
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
