Question about Asrock 775VM800 Motherboard
No display and dvd driver dont open - Asrock 775VM800 Motherboard
  • Asrock Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
as for the dvd
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Posted on Jan 01, 2011
Dvd code 10
Check the cord connection between the dvd player and the computer. Re boot the computer and then plug the dvd player in. Be sure the dvd player is connected to the power source.
You should "see" it on the computer as an icon if you are displaying the desk top
If not, click on the desk top Windows icon, and then click on Computer when the pop up comes on.
You should see the display of your computer and hard drives
The dvd player icon should show up under "devices with removable storage" there.
Re check the dvd is actually on.
Click on Control Panel and then "Hardware and devices" You will see your printer etc.
If the dvd player doesnt show up, try and open the dvd player to load in a disc. If the tray doesnt open, the player is defective
If it does, then the fault is in the computer "Device Manager"
Go to the computer Device Manager and you will see the device name with a red x against it.
The two possible faults are
1. The driver is missing or damaged
2. The device is defective
If you have the skilset, delete the dvd driver and install it again from the manufacturers (Toshiba?) web site
If you dont, find a geeky friend!
Feb 24, 2014 | Gigabyte Computers & Internet
DVD tray won't open
ur dvd store is stuck man
dont try to fix it ur self ...and contact u rdealer emidiatly
best regards & best of luck..
Oct 12, 2007 | Panasonic DMR-E85H DVD Recorder
Eclipse AVN5504D radio only displays eject cd, eject dvd, open. What is the solution, I dont have the eclipse disc.
plorer Stereo Problem - Ford Forum - Enthusiast Forums for Ford ...
www.fordforum.com > ... > General Ford Forums > General Tech
Nov 5, 2011 - The Eclipse AVN5504D stereo only displays eject cd, eject dvd, open. plus some asian writing at the top which I don't understand sorry.
Japanese navigation toyota,eclipse insert map disk solution ...
www.pakwheels.com > ... > In-Car Entertainment (ICE)
Oct 9, 2012 - 21 posts - ‎16 authors
Despite the radio having all the instructions in Japanese, it has been ... The Eclipse AVN5504D stereo only displays eject cd, eject dvd, eject ... More results from www.pakwheels.com
- avis des utilisateurs [ tradecarview ]
Jun 23, 2011 | Car Audio & Video
My laptop says I don't have a DVD burner but I do. How can I reinstall it?
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
if your computer came with a disc the drivers could be on it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
dont forget to vote
Feb 19, 2011 | Computers & Internet
Cant open my DVD player to put a disc in on the blu ray system. Maybe my little grandson pressed something I dont Know
when you press open does the machine display open...if it does then the door is probably jammed and you may need to have the unit serviced
Feb 05, 2011 | Sony BDP-S560 Blu-Ray Player
How do I program my emachines to recognize the dvd / rom drive?
you dont need to program anything you most probably are missing a driver for it, go to your start menu and right click on computer, a little window will appear next to it go to the bottom and select properties now in the top left corner you will see device manager open that now it will display a list of all the devices on your laptop if there are any devices with a yellow triangle with an explanation mark in it that device isnt working properly, so look at your CD ROM drive in the list if it has a yellow triangle double click on the on it it should of now opened another window with a few option click search computer for drivers if that fails click browse web for drivers, if you get stuck or if that doesn't work get back to me
Jan 19, 2010 | E-Machines M2105 Notebook
Dell cd/dvd drive doesnt work
If the CD opens and closes - the power is good the IDE or SATA cable could be loose or not connected - if the BIOS shows it but it does not read the CD is faukty - If the BIOS dont show it the jumpers may be wrong - CS /Master/ slave
Nov 06, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Issues!!help please
If you open the DVD from "Media Player Classic", i think it should work.
Go to the installation folder of K-Lite Codec Pack (Probably C:\Program Files if you didn't change it)
The open de folder "Media Player Classic" and execute "mplayerc.exe".
Make sure the DVD is in the DVD-drive and go to File -> Open DVD
If this does not work, I think you have a very special DVD, or the DVD is damaged...
Please post some feedback
Apr 22, 2008 | Dell InspironTM 1501 Notebook
EMachines W3400 DVD not opening
Go to your control panel, systems, hardware, device manager and see if the device is reconginzed. If there is a "!" by the DVD drive, there is a hardware issue or driver issue with the device.
Aug 16, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Akai DVD recorder tray will not open
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Aug 08, 2006 | Akai DVDRW120 DVD Recorder
Asrock 775VM800 Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
