Question about Maytag SkyBox MBV1976A Beverage Dispenser
Fan in maytag skybox has stopped working. I checked the fan with another source and it does work, so it may be the circuit board. Is there a way to wire the fan into another componet, other than the circuit board? I really don't want to pay $75.00 for a new board and the board may not be the problem. Please let me know. Thanks.
SOURCE: Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Posted on Jul 19, 2007
Master_Tech
  • 770 Answers
SOURCE: Maytag SkyBox
Both Check your emails
Posted on Apr 28, 2008
SOURCE: maytag skybox schematic
there is a basic schematic on the back of the unit
Posted on Apr 30, 2008
  • 3 Answers
SOURCE: MAYTAG SKYBOX REPAIR MANUAL
http://kitchen.manualsonline.com/manuals/mfg/maytag/maytag_skybox_by_maytag_personal_beverage_vendor.html
Here is a site that has the manual for this. Good luck! Mine was a piece of ****! Had to have it repaired twice because ice builds up on the motor and THEN the compressor went out. Most refrigerators have a 5 year waranty on the compressor but not these things, its a ONE year! Never buying Maytag again!!
Posted on Nov 13, 2008
SOURCE: Maytag Skybox dispenser
read a post that said to manipulate the sensor a little, but when I found out where the sensor was (it is in the back of the door, behind the panel just to the right of the opening and the flap behind two screws) I found that there was nothing wrong with the sensor at all. The problem was simply that my door flap was not closing completely (and thus not tripping the sensor). It seems that if the door does not close completely that the machine thinks that there is a jam. I held the flap down completely and pushed the button and out came a drink from any button. I cleaned the flap and lubricated it with a little WD40 and BAM, back in business. I could not believe it was something so simple. It took two minutes to fix! Hope your has the same so it can be that simple.
SK
Posted on Jan 04, 2009
Skybox beverage dispenser. will dispense one can
I had the same problem. Found the cover where the beverages dispense to be rusted and not resetting. After the can dispenses, just push the cover back into position and this should help.
Jun 09, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox cools but nothing else works, no LED lights, no dispensing
If none of the LEDs are working, sounds like the transformer has went bad. First look at the board for a fuse to see if its blown, if so replace, see what happens next. To check and change the transformer you need a volt/ohm meter. If you do, and are feeling ambitious, I'll need some info off the schematic or the transformer itself, and I will walk you through it.
Dec 28, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox stays at 50 degrees all the time
The SkyBox was built for Maytag by a company in China. Production stoppedabout 2 1/2 years ago, and Maytag purchased ALL available service parts available at that time. As inventories are depleted, there will be no more parts available.
An issue with the SkyBox involved a build up of frost and ice on the evaporator plate built into the wall behind the dispensor assembly. This build up insulated the product from the evaporator coil. It also caused the circulation fan to stop running. Unplug the unit and leave the door open for 24 hours. Plug it back in, set the thermostat indicator at the 11:00 position and close the door. See if this brings the temps back down to the 36 to 42 degree range, I hope this helps.
Jan 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox wont dispense
look for ice blocking the door on the unit and causing it not to fully open , good luck
Jan 08, 2009 | Maytag MBV1976AAP Beverage Cooler
Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox
I have a Sky box Model mbv1976aap series 10. It is complete but not working. I think it is the overload switch on the compressor as it arcs every time I plug it in. I don't want to fix it but I will sell parts for half price of parts direct website. I can be reached at scrapjunky@cox.net. I have dispensers, cooling fan, circuit boards, what do you need?
Mar 09, 2008 | Maytag MBV1976AAP Beverage Cooler
Maytag Sky Box Won't dispence
Since it's only one dispensor unit you should be able to eliminate "common" items and find out what controls just that one dispensor. The faint click may be from a bad relay (relay coil works but doesn't pass voltage on contacts). You will likely have to take the thing apart to check the control board. Here's a diagram of the unit so you can see where everything is at. I'd suspect the control board relay that controls that particular dispensor is bad or a loose wire, etc. http://www.partselect.com/Schematics/Maytag/VM10-1.gif
Jan 14, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
122 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
