Question about GE Profile PCF25PGW Side by Side Refrigerator With Ice Box
The ice maker tracks that it slide into broke and the back mechinism that cranks out the ice is broken i need the runner
  • 731 Answers
I think what you are looking for is what is called the bucket glide
It's number 359 on the diagram labeled Ice maker and Dispenser
If not this is the Sears site and they should have what you need
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PCF25PGWCWW/0432/0165000?searchedModel=PCF25PGW&blt=
Posted on Jan 01, 2011
Why would the window motor run and not drive the window up and down?
The window regulator needs to be replaced. It possibly fell or broke off the track
Oct 12, 2014 | Cars & Trucks
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Samsung RF266AEPN
How do I replace a broken ice full guide?
The ice maker is easy to remove once you get the drawer off the slides. There are two plastic clips located near the back of the drawer that attach it to the slides. Pop those out and lift the drawer out. Pull off the plastic ice maker cover to expose the mounting screws. Remove the two screws holding the assembly to the top of the freezer, then slide the ice maker forward about 1/2 inch. It will drop down a few inches, allowing you to unplug the wiring connector and remove it as a unit. The ice full guide is then easily removed.
Sep 06, 2013 | Samsung RF265AA Bottom Freezer French Door...
How do I reattache the DA61-03561 Guide Ice Full lever?
I have the same problem.
You will likely need a new one.
You can verify this as follows.
Remove the Ice catcher (using the lever on the right side).
There is a white Philips new the lower left front of the hollow area.
This screw holds down a long plastic cover.
After the screw is removed the cover can slide 1/2 inch towards the doors, then it can be removed.
Notice the little white hooks on the back that slide onto tabs (for when you replace this).
Reach to the back left of the hollow area - there is a cable that goes to the ice maker.
Free this cable.
On the top of the ice maker there is a little tab.
Press this tab and the ice maker can be slid forward 1/2 inch, then it can be lowered.
On the right side of the ice maker you will see a depression with a square depression in it, with a Philips screw in the center. This is where the Ice Full guide goes. You will likely notice it has broken off.
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker is broke how do i replace need to replace whole ice maker
If its broken is probably better and cheaper to get a new one than try to fix it or pay to somebody to do it.First unppluged the fridge take the two scrwes that holds the ice maker to the freezer side wall and another one in the bottom of the ice maker once is loose you'll see a plastic plug ,pull itout and you can take the machine off and put a new one.When installing the new one make sure that the filling plastic tube is right through the hole in the back of the ice maker.
Apr 23, 2009 | Kenmore Freezers
Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
seabreezehvac@yahoo.com
Dec 18, 2008 | Amana ARB8057CSR Bottom Freezer...
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Ice maker fill tube
most will just slide back in... unless it was broken.. some are attached to the outside in the back and go all the way thu .. i couldnt bring up you model #
Aug 27, 2007 | Amana SXD524VW Side by Side Refrigerator
Ice maker drawer for sub-zero 632
Look at both those tracks on each side. its likely one or both are cracked or broken. Each one has 2 screws holding it in. To put the metal hange back in the tracks, you must get new tracks (if broken/cracked) then hold the2 tracks onto the bucket carriage...then stick thewhole thing in as an assembly, hen put the 4 screws back in. there are 2 more small screws way in the back (one on each side), but they do not have to be removed, only there to guide the racks in properly. these tracks are only about 7 bucks apeice, and shouldn't take long to chamge. Good Luck!
Aug 02, 2007 | Sub-Zero 632 / S
GE Profile PCF25PGW Side by Side Refrigerator With Ice Box Logo
54 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
