Question about Dell Dimension 4500 PC Desktop
Wont boot correctly
When i turn on the computer, the screen goes to a Dell logo and wont go any farther. I have tried to press F8 and start it in safe mode to fix the problem...but no luck.
  • offthewall23 Jul 08, 2008
    OK...i turned on the computer...but there was no beeping. I turn it on and 5 seconds later it is at that dell screen again. no sounds, options, or anything...
  • 50 Answers
Typically, a system that won't pass POST (Power On Self Test) will beep in a pattern indicating what the problem is. Here's the beep codes for Dell systems:
Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Posted on Jul 08, 2008
Wont boot bios windows
Try pressing F8 while the laptop is booting and select "safe mode". If it boots fine in safe mode, it might be either driver issue or the laptop's videocard giving up. The driver issue is corrected by installing the right drivers, you can ensure if the problem is on the hardware side by setting it to boot in 640*480*256 (or lowest possible resolution) and see if it boots. Also, try pressing F8 during boot and select the option to log the boot process. The log file might then tell you what causes the stop/hang.
Oct 23, 2013 | Acer Aspire 5738Z-423G32Mn Notebook
Wont go into safe mode
->Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
->From Advanced Boot Options screen, choose Safe Mode option then press Enter.
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Oct 01, 2012 | Dell Inspiron Computers & Internet
Starts up until welcome screen, then goes black
Try Last Known Good Configuration. From shutdown turn the computer on and as soon as you see the DELL logo start tapping F8. Advance Boot Options will appear and then use the up or down arrow keys to go to Last Known Good Configuration and press Enter.
If that does not work:
Try booting to safe mode. After powering the computer up when you see the DELL logo start tapping F8 from your keyboard and then choose "Safe Mode" or "Safe Mode with Networking" if you're able to boot up successfully go to Start-> All Programs-> Accessories-> System Tools and then System Restore.
Restore your computer to a date when it was working.
Hope you found this helpful!
Apr 19, 2011 | Dell Latitude D505 Notebook
When i turn on the computer it goes to the windows loading screen and wont go past that, ive reset it, unplugged it , and it wont go past that screen The computer is a acer E2200 desktop and it runs on...
Have you tried booting into Safe Mode? You can do this by pressing/tapping the 'F8' key after the bios screen (Acer Screen) comes up. If it does you boot correctly then, you can try to restore the system to an earlier date using System Restore. That's located in the start menu/windows orb at All Programs->Accessories->System Tools->System Restore
Feb 28, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
When starting my computer windows wont let it load because it says there is a problem with a program or drive on a blue screen just after the windows xp logo appears(on screen half time normally is) i've...
Start your computer in safe mode (press F8 before you get the Windows splash screen). I usually suggest pressing F8 continuously as soon as you see anything on the screen.
Once you get the white menu up that allows you to enter safe mode, let the computer boot into safe mode and do a system restore back to when you know the system worked.
That should solve the problem.
Jan 16, 2010 | Dell Computers & Internet
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Nov 12, 2009 | Dell Inspiron 6400 Notebook
When i start up my dell inspirion 6000 laptop the logo comes up and then screen goes black
When you see the Dell logo, it means the system is booting and you see the splash screen that is generated on the motherboard.
Apparently this is where it is stopping.
Here's what I would do: First when you boot the computer, press F12 to get the boot options. Choose the diagnostics and run the system diagnostics.
You can also try to press F8 to get the computer into safe mode, but I'm thinking if you see nothing other than the splash screen, that may not work. If you are presented with Windows boot options, choose safe mode and do a system restore.
The last thing you can do if you have the Dell system recovery disk is try to do a repair from that CD if it allows you to do so.
Nov 06, 2009 | Dell Inspiron 6000 Notebook
Lenovo X60 Laptop blue screen error wont boot up
Try to go into safe mode by pressing F8 as soon as you turn on the laptop.
If you get into safe mode then go into system restore and choose a date when the laptop was working properly. Let it rollback to that date and reboot the computer and let it go and see if it goes back into windows.
If you get a blue screen even when trying to go into windows then the operating system is corrupted and you'll need to do a factory restore on the laptop, meaning the hard drive would have to be wiped out and the operating system put back onto the hard drive.
Aug 27, 2009 | Lenovo ThinkPad X60 Notebook
I have a Dell GX60 and I changed the display resolution and
So, with The computer, completely turned off, Turn it on, Can't you see the BIOS screen? , or a Dell LOGO?
It is when you see this BIOS or Dell logo Screen that you Need to:
  • PRESS F8
  • Press F8
  • Press F8, again, and again right when your computer turns on.
Then You should be brought to the Window that allows you to boot into SAFE MODE, DO NoT PICK SAFE MODE.
Pick: ------------ENABLE VGA (basically safe mode) Only!.
Once booted, log in and change the resolution to let's say 800x600,
then restart your computer normally.
You should then be able run windows normally, (Without F8 Key) where you can then change the resolution to what you want.
IMPORTANT! Remember this, if you set your display to a resolution that it Does Not
support, and the screen goes blank. DO Not Turn off your computer: ALL YOU DO IS PRESS
the (Esc) ESCAPE Key within 15 Seconds and your monitor's resolution will be set to it's
previous state again.
I Hope This Helps.
Jan 30, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Dell Dimension 4500 PC Desktop Logo
166 people viewed this question
Alun Cox
