Question about Amana AGR5712AD Gas Kitchen Range
Undo sabbath mode - Amana AGR5712AD Gas Kitchen Range
    Sergeant:
  • 223 Answers
Press the 'clock' pad, underneath the keypad, for five seconds. It should blink for a few seconds and then clear.
lp
Posted on Jan 01, 2011
I have an LG LRE6383ST range. When in Sabbath Mode, how do you know when the grill is on and off?
When in Sabbath mode the only thing that functions is the oven and it will remain on until Sabbath mode is cancelled. You can still change the temp while in Sabbath mode. If the light is on in the oven when Sabbath Mode is activated it will remain on. To turn it off you have to make sure it is off before turning on Sabbath mode.
Apr 04, 2017 | LG Kitchen Ranges
What does SABB mean on ge french door refrigerator
Sabbath mode someone pushed some buttons and caused this or touch panel shorting. Need to read owners manual to clear
Jun 20, 2015 | GE Refrigerators
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
Sep 02, 2014 | Frigidaire Refrigerators
Inside lights of KitchenAid KSF26C4XYY not illuminate
I bet your fridge was put into Sabbath Mode.
Sabbath Mode is designed for those whose religious observances
require turning off the lights and dispensers.
In Sabbath Mode, the temperature set points remain unchanged,
but the interior and dispenser lights turn off, all sounds and alarms
are disabled, the dispenser display screen backlight turns off, and
the dispenser levers are disabled
To turn on Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds. When the feature
turns on, "Sabbath Mode" will appear on the dispenser
display.
To turn off Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds again.
Apr 15, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
How to turn on sabbath control on my whirlpool stove
To Activate Sabbath Mode:
To use the Warm Zone and/or Warm Drawer during Sabbath Mode,
press the WARM ZONE and /or WARM DRAWER keypad before
activating the Sabbath Mode.
1. Press BAKE.
2. Press the "+" or "-" key to set a temperature other than
350F (177C).
3. Press START.
For timed cooking in Sabbath Mode, press COOK TIME, then
the "+" or "-" keys to set the desired cook time.
4. Press TIMER SET/OFF for 5 seconds. "SAb" will appear in the
display.
To Adjust Temperature (when Sabbath Mode is running):
1. Press the "+" or "-" keypad. Each press of a keypad will
increase or decrease the temperature by 25F (14C). No
temperature will appear in the display.
2. Press START.
To Deactivate Sabbath Mode:
Press and hold TIMER SET/OFF for 5 seconds to return to regular
baking or press CANCEL/OFF to turn off the range
Feb 09, 2013 | Kitchen Ranges
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I cancelled the clean proprocess and then the display shows 5ab and I can't get the oven to work or clock .. anything, no beeping
somehow you put it in sabbath mode,yes sabbath mode,a feature known as "Sabbath mode." According to the Jewish Sabbath law, raw food may not be cooked on the Sabbath, but food that was already cooked beforehand may be kept warm until mealtime. On Jewish holidays, food may be cooked fresh, but turning the flame on poses a problem given electrical requirements forbidden by Sabbath observers.try holding the clck button in for 3 to 5 seconds to take it out of sabbath mode
Mar 27, 2011 | Amana Kitchen Ranges
How set sabbath mode??
to turn on or off the sabbath mode on your oven press and hold the sabbath mode button for 5 seconds that turn it on and then repeat to turn it off
Apr 04, 2010 | KitchenAid KEBC107 Electric Single Oven
Nothing on my display works and says 5ab where the clock would be
assumingyou still need the repair , your in SABbath mode, consult your user manual for the procedure to undo, common occurance, especcially after turning the clocks back
Nov 04, 2008 | Crosley CE35100AA Electric Kitchen Range
Amana AGR5712AD Gas Kitchen Range Logo
65 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
