Question about Fuji FinePix A805 Digital Camera
When I turn it on it beeps and the screen says protected card, what does this mean
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on May 04, 2011
Advent 7102 hear 2 short beeps, blank black screen when turn on
you have a AMI BIOS system and with AMI BIOS 2 beeps means there is a problem with the RAM if you have two cards remove one then try to power on if it still beeps twice swap the RAM and try again if it still beeps twice see if you can borrow a 200pin DDR-333 SODIMM RAM card from someone that is deffinatly working if it starts with that you need to replace the RAM cards
Oct 19, 2013 | Computers & Internet
Hi, Id really appreciate it it if you could help me fix this problem with my camera. When I turn it on it beeps and it says -card full- on the display screen, the problem is that Ive NEVER used this card...
here are the manuals in 4 part downloads
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=615
just in case you have lost yours. It says to format the card, and check to see if the write protect is on on the card. you may have a bad card as well. I know you said you have never used the card, but this doesnt mean it is a good card, it only means it doesnt work. If you have a friend with a working card, first take all the photos off his card then try it in your camera to see if it works.
Jun 13, 2011 | Olympus C-3000 Zoom Digital Camera
4 beeps and no screen when i turn on my enovo desktop
One long beep followed by three short beeps means that either the video card isn't installed or the memory on the video card is bad. Reseating or replacing the video card will typically fix the cause of this Intel beep code.
Mar 10, 2011 | Lenovo ThinkCentre M55 Desktop Core 2 Duo...
It is not showing the post screen and beeping a long and continuous beep
a long beep is identicated your vga has trouble, but maybe it caused by ram error, first turn off your computer, open computer case, disconnect your ram and connect again, turn on computer, is the computer still beeping??if yes it mean the problem come from your vga card, do not use onboard VGA port, just insert PCI or AGP VGA card, your computer will work properly
i hope this helpful
thank you for using fixya
Feb 04, 2011 | Foxconn (945G7MA-8KS2) Motherboard
Screen will not light up and there is beeping at the start up?
Hello tiann3
The beeping as you start the computer is basically a message telling you what is wrong with it.
if you have slow and somewhat long beeps it generally means memory 9RAM) problem. could be faulty or loose RAM. If you have more than one piece of RAM you can test them by turning the computer on with one piece of RAM at a time.
If the beeps are faster and shorter, it means problem with graphic card (if your graphic card is on integrated).
good luck
if this was helpful please leave comment, vote.
Jan 08, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Pc turns on but screen says no signal
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card.
  • When the PC turn on there is any beep.
  • If no beep then your RAM is alright.
  • Problem in VGA Card.
Mar 15, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
My monitor is not displaying anything. other things are working fine but the screen is not displayed.i lost my driver cd so downloaded the driver software for this card from the net. it showed me a blue...
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card. When the PC turn on there is any beep. If no beep then your RAM is alright. Problem in VGA Card.
Feb 20, 2010 | Computers & Internet
Lap top has lights but does not turn on
Check what the beep codes mean. It can tell whats it meaning.Could be a fault in RAM or other expansion card.
Apr 11, 2009 | HP Pavilion dv2500t Notebook
What does "memory card is write protected mean?" I can't take any pictures
when i turn on my nikon coolpix the screen says memory card is write protected what does that mean
Dec 07, 2008 | Nikon Cameras
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
Fuji FinePix A805 Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
