Question about Linksys Wireless-G WRT54GS Router (e125894)
How can i block other users to access my wireless network.
  • 23 Answers
You need to set up network security on your router. Go to this link and it will walk you through setting it up.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=cfb50c0dc992443ab2405a782cca60f7_19073.xml&pid=96&slnid=4
Posted on Jan 01, 2011
How can I configure the Internet Access Policy under the Access Restrictions tab so that only certain workstations/users (connected to my network through the wired and wireless options) will have access to...
Hi Wilson,
You can block Internet access by specifying MAC addresses of PCs you want blocked. The MAC address is the physical address of the network card in the PC.
Please page 54 for instructions on setting up this policy.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000000300.pdf
To locate the mac address of a PC.
click Start, then Run, then type cmd in the text box.)
Type in ipconfig/all in the Command Prompt Windows. Review the output.
The 12-digit Physical Address is the same as MAC address
Sep 02, 2011 | Linksys Wireless-G WRT54G Router
How do I set my Toshiba to wireless network? I have used a cable modem since purchase?
1. Make sure your Wireless LAN switch is turned on. For most Toshiba notebooks, this switch is located on the front left side of the notebook. Consult your user manual for more information about where the switch is on your particular system.
2. Check to make sure that the Wireless Device is properly enabled and configured.
3. Make sure that you have been given access to the wireless network. Check with your system administrator or host provider.
4. Make sure that there are no walls or other obstructions blocking the radio signal from reaching your notebook. Try moving closer to the Access Point.
Jul 04, 2011 | Toshiba Satellite L455D-S5976 Notebook
Get no signal from router
There are many network-related settings that need to be configured on the system for connecting to a wireless network. If even one of these settings have not been configured properly, issues will come up. All users facing problems with the use of wireless networks are advised to check network-related settings such as access points, IP address in use and reconfigure them if they are not properly set. Users are also suggested to check the firewall settings to make sure that the firewall is not blocking network connections.
http://router.iyogi.com/wireless-network/wireless-network-not-working.html
http://www.informationweek.com/news/mobility/802.11x/216403550
Jun 10, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Is there a limit to the number of login attempts that can be made or can hackers make continuous attempts until they get in?
There is no limit to the number of login attempts, as far as I know, but there are ways to block hackers outside of your network...
You can use MAC Filters (Media Access Control) to allow LAN (Local Area Network) computers by their MAC addresses access to the Network (p. 44 in the user manual).
You can also use the built-in Firewall Settings for protection from the outside world (p. 45 in the user manual).
There is also an Access Control Wizard (p. 40 in the user manual).
Here is the PDF link to the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
Apr 15, 2011 | D-Link DGL-4500 Wireless Router
How can I block external users in the area useing my data allocation
You want to enable encryption settings. What this means is in order for you to connect to your wireless network you need to enter a password/encryption key to access your internet. Enable wpa encyrption adn then type in a enyrption key of your choice for example your phon number 2225551212.
http://www.techduke.com/2007/05/18/how-to-encrypt-your-wireless-connection-on-d-link-wep-key/
Mar 03, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
Wnr84b wireless settings security options only has 2 options
mostly u will be getting more security options oly with the high-end wireless devices. apart from the default security options, u can secure ur wireless network by many ways. turn off dhcp server in ur wireless router or access point. so it avoids unauthorized users from accessing the network. instead u may give a static private ip address for each and every wireless users for getting wireless access
Jul 22, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How to block users from accessing your wireless service?
You need to set up network security for your router. Set up a network password. I would recomment WEP since it is the easiest to manage. Make sure you save the password so that you can add to or change the network. You can get the instructions and manual for your particular version of the WGR614 at
http://kb.netgear.com/app/products/family/a_id/1296
Please rate this solution. Thanks.
May 19, 2010 | NetGear WGR614 Wireless Router
New Modem with a router for wireless Laptop
Some routers have a kind of built in firewall. You need to let the router/modem that it is okay for it to let this information pass through it. Here are your instructions
Overview
Follow the steps in this chapter and use the Gateway’s web-based utility to configure the Gateway. This chapter
will describe each web page in the Utility and each page’s key functions. The utility can be accessed via your web
browser through use of a computer connected to the Gateway. For a basic network setup, most users only have to
use the following screens of the Utility:
• Setup. On the Setup screen, enter the settings provided by your ISP.
• Security. Click the Administration tab and then the Security tab. The Gateway’s default username and
password is admin. To secure the Gateway, change the Password from its default.
There are seven main tabs: Setup, Wireless, Security, Access Restrictions, Applications & Gaming, Administration,
and Status. Additional tabs will be available after you click one of the main tabs.
Setup
• Setup. Enter the Internet connection settings on this screen.
Wireless
• Basic Wireless Settings. You can choose your wireless network settings on this screen.
• Wireless Security. This screen allows you to choose your wireless security mode.
• Wireless Network Access. This screen displays your wireless network access list.
• Advanced Wireless Settings. On this screen you can access the advanced wireless features.
• WDS. The wireless distribution system feature is accessed on this screen.
Security
• Firewall. This screen contains filters and the Block WAN Requests feature. Filters block specific internal users
from accessing the Internet and block anonymous Internet requests.
• VPN Passthrough. To enable or disable IPSec and/or PPTP Passthrough, use this screen.
Jan 20, 2009 | Linksys Computers & Internet
Linksys router
The most direct way is to use the software to block by Mac address. Each computers card has a unique network ID that you can look up and then enter into your LinkSys.
Apr 22, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys Wireless-G WRT54GS Router (e125894) Logo
41 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
