Question about Sharp R-408J Microwave Oven
My sharp microwave started sparking - Sharp R-408J Microwave Oven
  • Sharp Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal is damaged, the area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 02, 2011
Sharp carousel R-930-AK microwave is sparking how to stop it afraid to use it
Sparking could be caused by something metallic inside the microwave! Check in side for anything metal like foil!
Nov 02, 2014 | Microwave Ovens
Sharp R402JK-T sparking on starting
Unplug the unit and do not plug it back, I can almost picture someone doing this, watching the sparks and smoke and oh the lights dim--Be smart here===either replace it out of hand or take to a repair shop to see if worth fixing or not and do not attempt to turn it on again.
Dec 12, 2012 | Sharp R-9H66 Microwave Oven
Sharp r1214f sparking New issue sparks with microwave popcorn, butter and microwavable ice cream.
the container of these items probably contain some metal which doesnt go with the microwave
Jul 19, 2010 | Sharp R-1214 Microwave Oven
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
R-1214 Stainless Steel 1100 Watts Microwave Oven: turns on buts starts sparking in a few seconds. ...
what's sparking... is it by the Magnatron window... or the carousel?...
If there is a carousel... take it out...
if its by the magnatron window,,, then...houston... we have a problem...
might be contamination... and that may require opening up the unit... sorry...
hopefully it's only something floating around in there that's causing the arc...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | Sharp R-1214 Microwave Oven
Sharp r-930ak microwave oven is sparking
A dirty or damaged wave guide cover can cause sparks, fire and noises. You can order a replacement wave guide cover from many appliance parts websites for less than $15 in many cases. It should fix the problem.
May 03, 2010 | Sharp R-930AK Convection/Microwave Oven
It gives of sparks while heating anything! It is a Sharp microwave.
Time for a new one, when they start sparking, they're dying.
Oct 26, 2009 | Sharp Microwave Ovens
Sharp selling bad microwaves
paddy paddy paddy i want i want, bet you were spoiled as a child, never continue to use a microwave that sparks, you can only do more damage to the appliance and maybe even worse is this sparking when you use it under normal conditions, place a plastic bowl with cold water in and see if it sparks then, if not then is it something you have done, i assume you know what you can not put in a microwave if sparking occurs anyway, and its only 6 months old, is it under guarantee, then its simple, send it back and ask for free replacement SHOUT AT THE RIGHT PEOPLE DON'T WASTE TIME ON HERE
Oct 04, 2007 | Sharp R-220BW Microwave Oven
Sharp R-408J Microwave Oven Logo
147 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
