Question about Panasonic Heating & Cooling
Our ac is not responding to the remote control?we changed the batteries and i can see the little red light on the remote but the unit not turning on?help please!
  • 2,133 Answers
There is transmission problem. Check your remote sensor with camera phoneand press any button. If ultra light flashes, your remote is O.k. And some times your receiving sensor in PCB also be a defective. Check with same type another remote.
Posted on Jan 01, 2011
I have a videocon vitaair AC . The remote control function is not functioning. The AC is not receiving any signals from the remote. Remote control has new batteries and display working.kindly help.
you can check if the remote is transmitting by looking at the end of the remote where the little bulb is that you point at the air con unit through a smartphone camera and press each button, if the light flashes the remote infra red transmitter is sending. your mobole camera can pick up light in the part of the spectrum your eyes cannot and displays as a flash. it will at least let you know if the problem is the remote transmitter or the units receiver
Mar 02, 2017 | Televison & Video
Only red standby light comes on,Hit power button on remote, light goes out,unit turns off and have to replug into wall to get red light on.
There would be some problem in the output amplifier stage. Thats why its going to protection mode.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 18, 2016 | Audio Players & Recorders
Where is the infrared receptor card in this equipment to change it. I have a split ac panasonic CS C24BKP and does not respond to remote control. I know the remote control is good because I saw thr...
There is a receptor on the below the front pannel but the problem could be :
1.Low battery charge in the remote control.
2.The signal cable that connects the receptor to the card(pc board) could be loose/disconnected
3.Try one receptor from a working unit
4.Try a remote control from a working unit
Regards,
Adamson
nyauadamson@gmail.com
May 02, 2014 | Heating & Cooling
Fan unit not responding to the remote to change speeds
The red light on the remote is the battery indicator light. You probably need a new capacitor. Take off switchcup & check black box to see if it is going bad.
Jul 10, 2013 | Hampton Bay 46056 Callaway II Ceiling Fan
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
Red light on remote came on after battery changing and will not turn off or respond
Hello, Becki Barned with DISH Network customer service here! Sometimes, when you change the batteries in the remote, it needs to be reprogrammed. Just follow these simple steps to get it working!
http://www.dishnetwork.com/SupportSection/remote-control
Dec 31, 2010 | DISH Network IR Remote Control
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Heating & Cooling Logo
498 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
