Question about Proform iLog 750 Treadmill
Treadmill seems to start out OK but after maybe 2 minutes suddenly bogs down to about half speed then will stop all together if keep trying to go. If step off the belt after it bogs, it will speed up to correct speed again and is fine if stay off but will bog back down if get back on the belt.
  • Proform Master
  • 6,694 Answers
check the motor and the motor controlling card. check the motor is it over heating or not. also check the speed sensor beside the motor pulley. clean the speed sensor and refix it. then test again
ok
Posted on Jan 01, 2011
  • Electro Med Services
    Electro Med Services Mar 07, 2016
    If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.http://electro-medical.blogspot.com/
I have a Gold's Gym trainer 410 treadmill. I
please RUN the software calibration for easy diagnostic and fix it.
Go under the HOOD cover for motor, and see the instruction and follow the instruction
God bless you
Jul 20, 2013 | Exercise & Fitness
V-fit treadmill won't start and shows error message.
Test the power supply coming to the equipment and try again. If the problem with power is o.k proceed with LUBE very important. God bless you
Apr 07, 2013 | Exercise & Fitness
Scooter keeps bogging down and missing when warmed up
Have you ever cleaned out the carburetor? Rebuilt it or cleaned it out chemically? Might also have a weak spark - check out your coil.
Sep 06, 2017 | Sport & Outdoor - Others
Client run on treadmill then suddenly its stop and display an error speed, then 5 seconds treadmill belt moves again and moves faster whats the problem of that?
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Feb 25, 2011 | Life Fitness 9100 Next Generation...
I have a proform 785..the problem is the speed and incline decreases all of a sudden like within a minute...i raised the speed to 4 and it dropped to 2 within 1 min and same thing with the incline it...
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Jun 11, 2010 | Proform 785 CS Personal Trainer Treadmill
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
Yamaha 2001 ttr 250. Bogs above half speed, under load
I have the same problems with my 1999 TTR 250, were you able to find out anything?
Walt
goalhawk@hotmail.com
May 04, 2010 | 2002 Yamaha TT-R 250
2001 yamaha ttr 250, starts, idles ok, bogs at acceleration
Has the bike been stored for any long length of time?
old fuel in the carburetor will turn to a varnish like residue blocking the jets,or possibly water in the carburetor.
May 03, 2010 | 2002 Yamaha TT-R 250
The belt stopped suddenly and now won't work anymore
I would check your speed sensor. I've never seen one of these just stop suddenly. But running for a min or so is one of the signs a speed sensor gives you.( especially if the treadmill want speed up while it running) Check this out and if it"s not the problem get as much info as poss to help diag.
Nov 16, 2009 | NRS Golds Gym Preview 1000 Treadmill
Proform iLog 750 Treadmill Logo
468 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
