Question about 2wire (1000-400108-001) Router
Need to find WEP security number - 2wire (1000-400108-001) Router
  • 600 Answers
  1. Connect your computer to the wireless router. Although you can access the router wirelessly, it is better to use an Ethernet cable to directly connect to your router so that you can securely adjust router settings. Plug the Ethernet cable into the appropriate Ethernet jack on your computer. Plug the other end of the cable into any one of the open Ethernet ports on the back of your wireless router.
  2. Open your computer's web browser(INTERNET EXPLORER). In the URL address field, enter the IP address for your wireless router(the DEFUALT GATEWAY). This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.
  3. Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers.try ADMIN" for user name and "PASSWORD" for password
  4. You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.(aka passphrase)
This FREE Tech support is provided by volunteers--If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Posted on Jan 01, 2011
What is wep"? on wifi
the devices like laptops and tablets connect to the wi fi router through a number of connection types. Some are direct and some are secured. The secured connections require a code that is set up during the configuration of the wireless network router. One type of secure connection uses the WEP code. (wired equivalent privacy) . If your device is asking for a wep code then the router has been set up to ask for this code. You will need to find out what the code is. If you are not the owner of the router then you need to ask the owner. If you are the owner and have forgotten the password then you could factory reset the router and use the default setting. But this is risky as anyone can connect to the network around your place.
Wired Equivalent Privacy
Sep 15, 2014 | Computers & Internet
How do i find wep key
Connect your router to computer with lan cable then you can access it with default link http://192.168.1.1 then type user as "admin" and password as "admin" or blank or "password" then you can see settings of router. Click on wireless then wireless security WEP key note down the code it is your password to connect wireless. Let me know if you need further assistance. Thanks for using FixYa.
Apr 06, 2011 | D-Link DIR-615 Wireless Router
I need my wep key numbers
Open the device page, navigate to security settings and the WEP key info should be in there, if it is asterisked out, simply set security to no wep no wpa and save the info. then if you want generate a new wep key
Dec 29, 2010 | Computers & Internet
Informed WEP key is a 10 digit number. could 231408&sid nos. & characters be my WEP key?
A WEP key is a security code used on some Wi-Fi networks.A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F.
The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
WEP keys are chosen by a network administrator, it would have been provided by the Internet Service providers, Hence it can't be as what you stated.
Oct 30, 2010 | Computers & Internet
Is the PIN on the bottom of the router the same as the WEP or WPA?
WEP or WPA are the types of wireless security. If your wireless network is secured then there will be a password on the network that is called as wireless network key or passphrase ( WEP or WPA key ). PIN number is different than WEP or WPA.
To check the wireless network key ( WEP / WPA) you will need to access the router settings page.
On that page , you will find all the settings of the router.
Apr 29, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
How do I secure my sbg900 from outside users
You need to set security to the router, even if you use wep, it is better then an non secured.
Its hard to explain all the details, please read your manual as this will walk you through the process, wep is easy and the more security you have the more detailed.
You can also set your router to only see your mac address, your mac address is the address of the wireless lan that is in your laptop or computer, each one has a specific number, and it is usually a 12 digit
number.
Every router is different in the security it has and some only have wep, so it depends on your router what security you can set.
If you don't have the manual just go to the website of your MFG and download it.
If you have more questions or help after reading it please post back.
Feb 06, 2010 | Arris SURFboard SBG900 Wireless Router...
How do I get a WEP security # to add a wifi picture frame??
The WEP number is a security code that is programmed into your wireless router through the web configuration page to prevent unauthorized access to your internet.
If this is your wireless network then you must have input the security code (its most probably 64bit meaning ten alpha-numeric digits).
Nov 05, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
What is WEP and WPA encryption
WEP is like a clear connection with no encryption only to get this connection you need to enter key number and password.
WPA is more like encrypted connection and to that also you shall enter key number and password.
In today's wireliss connection speed there's no differences and you better use WEP since they got less connectivity problems
Nov 19, 2008 | Computers & Internet
How to lock a linksy box?
Logon to your routers settings. normally by opening the following web page http://192.168.1.1
  1. Now click on the "wireless" tab
  2. Click on the "Wireless Security" sub tab
  3. In "security mode" select "WEP"
  4. Leave the "default transmit key" as it is
  5. Change "WEP Encyrption" to "128 bit"
  6. In the "Passphrase" enter anything you want. Make it about 8 characters long
  7. Press "Generate" and you will see Key 1, 2, 3 and 4 now have 26 Digits in each. Congratulations you have now secured your router and gernated your WEP key.
  8. Now you have 4 keys, you only need to use . But which one??? Easy. Above where, it says "Default Transmit key" and a number, 1-4. The number that selected is the Key you need to use i.e if 1 is selected use the letters in Key 1.
May 17, 2008 | Linksys Wireless-G WRT54G Router
Belkin g4 router
1.go to routers' setup, enable wep security and in wep menu insert a number about 8 digits
2.then go to wireless connection on your pc and in security menu enable it and check wep key
Nov 25, 2007 | Belkin (F5D5231-4) Router
2wire (1000-400108-001) Router Logo
114 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
