Hello, Well I have a Jensen antenna( Perfect for HDTV). How do I tune the antenna into a Soniq LCD TV Model E16Z10A. I can only get SBS channels and a few 9 channels. I have done everything! I need your help. Regards David
I have the same problem with my soniq hd tv i got a digital antenna that plugs into the power and i have also tried the roof antenna and neither worked.. Could it be the tv?
Posted on Mar 13, 2012
5 Suggested Answers
SOURCE: cannot tune channels eg channel
i had same prob untill i pluged it into a wall antana went auto setup australia DTV only and i got 7, 73 ,70, 71 , 90, 99,9,10,1,11, when pluged into a portable tv antana i lost 7, 73 ,70, 71 so that how i fixed my problem
Posted on Jan 08, 2011
SOURCE: LG 42 Cm HDTV TV Twin built in tuners turns its
http://www.retrevo.com/support/LG-42LC2D-TVs-manual/id/373ag102/t/2/ Above is your user manual, below is your service and repair manual. http://www.givemefile.net/smanuals/lcd_tvs/lg/42lc2d.html
Posted on May 27, 2010
  • 713 Answers
SOURCE: My antenna blew down in the storm the other
your aluminuim coils from inside antenna is damaged rap with aluminium foil intell u get another one.
Posted on Feb 17, 2011
  • 517 Answers
SOURCE: I have somehow "tuned out"
Good day!
please try to reset all channels by performing a auto scan...
go to the menu and find auto scan using your remote..
Or some remote have a direct button on the remote please look at your remote if have auto scan..
Thank you and good luck
Posted on Jun 08, 2011
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a Vizio 55" m550nv with Lip sync issues.
Hello
Just do this first and determine the fault. Connect your Vozio to an external antenna, to its antenna socket, and set it to autotune. You can refer to its user manual to how to do this. Let the TV tune all transmitting stations at that time, and memmorize it. After auto tuning is complete. select the channels one by one and check if they are perfect in every respec or not. Itf they are perfect, your cable TV operator is lying. As I know, Vizio is a perfect set. Do the above and determine. If the transmitting stations are also bad, surely your TVs tuner has damaged, and should be replaced with same type and number.
OK.
Feb 23, 2011 | Vizio M550NV 55 in LCD HDTV
Hi my lg lcd model no 42LB9DE works fine apart from 1 tv channel has perfect pic but no sounds have re-tuned tv many times to no avail... any ideas ? Tv antenna is is proper working order only 1 channel i...
by reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
Feb 16, 2011 | LG Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
How to convert the J53 BW to receive digital broadcast signals
Certainly you can use your TV!
The converter box needs an antenna so it can tune the channels, but it doesn't have to be the antenna that's built into the TV. In fact, you'll get better reception if you use an antenna designed for the new DTV broadcasts. Several types are available at stores where they sell TVs, and they start at under $10.
Then you'll need to connect the converter box output to the TV so you can tune it in on channel 3 or 4. I'm not familiar with your Jensen set, but I've never seen a TV without some kind of connector for an external antenna. The most common type on small TV's is a jack similar to an earphone jack. Radio Shack sells an adapter that plugs in and allows you to connect the cable from the converter box. Take the set with you if necessary so you can find what you need.
Feb 08, 2009 | Jensen J53-BWR 5 in. Portable Television
Poor tv reception on my new lcd screen
Hi, sounds like the antenna. Maybe get an Aerial company to check it out for you as you might not be picking up a strong enough signal.
Dec 27, 2007 | Televison & Video
Televison & Video Logo
323 people viewed this question
Top Televison & Video Experts
Electro Med Services...
