Question about Frigidaire GLRT182SA Top Freezer Refrigerator
My freezer seems to leak water from the plastic duct that covers the evap fan.I noticed on this gallery model that the freezer back cover does not have louvered vent like other similar 18cf models. All it has is a small space at the bottom of the metal plate. Did Frigidaire change the back freezer plate with louveres because of this ploblem? The water drain in the refrigerator temp control unit appears to be working!
  • kent mc donald Jan 04, 2011
    The sloted defrost water drain in the freezer unit was frozen with ice. The cooling fins on the have a little ice on them, the freezer and lower refrig section are both cold. I read on FizYa about maybe needing a drain heater that wraps around the defrost heater and sets down in the slotted freezer water drain. If you agree with machinetech7 that I should try this next, where can I obtain this part? It is not listed on any fridigaire parts lists
  • 4,059 Answers
Part 17 on this diagram is your drain trough. It is behind the evaporator. The frost melted during the defrost cycle drains through it into a tube. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Posted on Jan 01, 2011
  • Charles T Nevin
    Charles T Nevin Jan 05, 2011
    You can take a bare copper wire and wrap it around a fin on the evaporator and run the other end down the drain a couple of inches and the heat from the heater will conduct through the wire and prevent it from freezing although if the water drains fast enough it won't freezer. Try to see that it drains quick.
Whirlpool freezer won't freeze
you need to send the model number so i can see what fridge you have,is it a side by side freezer on top or bottom.check the back inside wall of the freezer to see if any ice or like snow is on the back inside wall of the freezer,if so you have a defrost problem,if it's a top freezer is there any water leaking into the fridge section,check under the crisper draws,if water is there you could have a blocked drain in the freezer,the water that's from the defrost mode leaks into the air ducts and freezes,or you could have a freon leak in the sealed system,remove the inside back wall of the freezer and check the frost pattern on the evap coil,if there's frost just on the top of the coil and nowhere else on the coil you have a freon leak,one more thing you could have a bad evap fan motor,open the freezer door,you should hear the fan blowing around,open the freezer door and push and hold the door or light switch in for a minute and then let it out,if the fan doesn't run it could be bad.the last thing is the compressor isn't running and you're hearing the condenser fan running and not the compressor,the start device on the compressor could be bad,feel the compressor,is it hot and feel it to make sure it's running.so bad start device,freon leak,defrost problem or bad evap fan motor or condenser motor.if you get back to me and let me know what you find and send the model number i can help you better.
Nov 02, 2011 | Refrigerators
I have an old kenmore fridge maybe a 90's model it's an off white color probably from age and alittle rusty, it's a top freeze and the freezer works great but the fridge section can barely keep...
all the fridge does is the freezer gets cold and the evap fan blows cold air from the freezer down into the fridge section,so open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,also the drain can be blocked and it freezes up the air ducts so the air can't circulate down into the fridge,is there water under the bottom crisper draws?if so the drain in the freezer is blocked,you have to take everything out of the freezer,remove the back wall,melt out all the ice and clean out the drain under the evap coil.i use a steemer to clean out the drain,if you don't have a steemer you have to melt out the ice in the drain with the hair dryer,then get like a turkey baster or anything that can blow down into the hole,pour hot water into the drain,if it drains out then you're done,if it doesn't keep hitting it,another thing is touch the inside back wall of the freezer,if there's like frost or like snow covering the back in side freezer wall you have a defrost problem,bad defrost thermostat,heater or timer,the last thing is the door was left open,you can tell this by looking at the food packages and the ceiling and walls,if you see frozen water droplets on your food packages or on the shelf or walls the door was left open and the air ducts are frozen,you have to melt the ice out of the air ducts.so open the freezer door,listen for the fan,no fan could have a bad fan motor,look for ice on back inside freezer wall or frozen water droplets,the door was left open or you have a defrost problem. also when was the last time you vacuumed out the coil unless it's on the back wall,if the coil is behind the bottom kickplate vac it out that will make a big difference.you can get back to me and let me know what you find or melt it out with a hair dryer like i said.good luck and let me know what you find.one more thing,if your ice cream is not staying hard just soft you could have a leak in the sealed system,but if i were you i wouldn't put any money into that machine,if you change it out you'll save money on your electric bill and usually once something on those old dogs starts to go wrong it's not long before it totally dies
Sep 22, 2011 | Kenmore Refrigerators
We have a whirlpool refrigerator-freezer (the freezer is on top). We have noticed water is leaking into the refrigerator from the freezer. why is it doing this?
This usually happens when your drain line gets clogged and freezes. When this happens and the fridge goes in to defrost the water from the Evap coil has no were else to go except to leak through the ducts in to your fridge section. To verify this you need to take the back cover of your freezer out so you can see the drain pan.
Sep 01, 2011 | Refrigerators
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Vegetable bin keep freezing food. Model # ED2CHOXKQ05
That can be the result of a couple things. Check to see if you hear the fan running in the freezer side? If not, since cold air falls, the cold air could be migrating from the freezer into the frig bottom section through the air duct hole in the back of the frig behind the crisper drawers. If the fan is running the check the air damper in the top left of the frig section. If the frig side is cold enough you should not feel air blowing through. Air flow is only very slight. You will have to remove some plastic cover or duct piece to see if it is closing. If the air damper seems to be working properly, you may have a refrigeration problem indicated by frost build up on the lower part of the freezer back wall. You may want to call in a pro at that point. Hope this helps point you in the right direction. Good Luck
Mar 12, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
I have a top-mount Frigidaire Gallery frost-free freezer, and everything in the freezer and the freezer interior is covered with ice crystals. Suggestions?
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Frigidaire FRT15B3A Top Freezer...
Side by side gallery ...water leak
  • it sounds like the water valve is not closing fast enough.
  •  this will cause the ice-maker to overflow a little.
  •  your ice-maker may have an adjustment on it to control how long it keeps the water valve on.
  • it should be a screw with a + and - sing on it. it may be under the ice-maker plastic cover.
  • if it keeps doing it then you may need a new water valve.
Jun 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator won't cool
We bought a Kenmore Elite Trio 596.76533500 from Sears in 2006. A few months passed and the Elite broke down. The tech person came out and found that the AC Evaporative Fan was inoperable. It was replaced (part #67003917). A few months later the same thing happened. But before they came out, I spoke to the tech person on the phone who seemed very familiar with the fan. He said that they've had numerous problems with that fan model and would bring out an older-type one that had fewer sensors and that was less prone to failure. The "motor evap" part #2214986 (Whirlpool compatible) was put in and everything has been working since... Hope this helps...
Dec 01, 2006 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire GLRT182SA Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
