Question about Azza Orion 201 black/silver SECC Steel ATX Mid Tower Computer Case (Mail In $20.00 Expires 07... (CSAZ201) ATX Mid-Tower Case
My Side and rear fan are not turning at all. If I nudge the side fan it will go on its own but the rear fan wont start at all. The cpu fan and PS fan work fine and the front case fan works fine. Im getting ready to take the case back to microcenter
  • 34 Answers
Buy new fans with same connecter.im sure u wont have that problem anymore
Posted on Jan 25, 2011
No video, hard not running, fan not spinning, but i try my memory to another laptop, its working. and power is stable. pls help me to fix my tg averatec 8200 series?
Had you notice that the laptop would start up, then a while-time later would shut down ? Were there times that you had to keep turning on the laptop because it would shot down?.Have you notice that the FAN was not spining?, did not hear it (noise) spin?
If that is so, you could have damaged the MOST important part of the laptop...the CPU (Central Processing Unit) It is the heart of the computer\laptop. Try one more thing. Place to the side of the laptop where the FAN output would be a FAN (could be small, but MUST be powerful) blowing at an angle INTO the laptop. Turn the laptop on (by the way REPLACE memory sticks and anything that you took out). If the cpu is damaged it may be have to be replaced.It can be done, but sometimes difficult!!
P.S. you must see if your original FAN is working, then that must be replaced also...
Sep 01, 2011 | Computers & Internet
Ice Maker quit, everything started to thaw out.
Good day,
Limited information. The ice maker will go into auto lockout if the freezer goes above 14 degrees.
Motors make noise.
There is a fan motor behind the back wall, of the freezer compartment. If the machine is turned on, it should run, and you should be able to hear it.
If not, remove the rear panel and inspect.
The second fan motor, is located in the back rear of the machine, behind the rear cover, it should be running as well.
If both are running O.K. then it is in the compressor itself.
A pricey problem, if it's the compressor. Should be checked by a qualified tech.
P.S. If you feel it is a compressor problem, and the unit is less than 5 years of age, then contact your selling dealer. It would be under warranty.
Thank you for using FixYa
Jan 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
I am in the process of setting up a barebones VBBI-2N7300 (installing Windows 7 on new sata drive) and noticed that the clear fan on the side and the large muffin fan in the rear are not on. Please advise....
There should be 2 male fan connectors on the motherboard, one is for the CPU fan and the other is for the case or system fan, this will marked on the motherboard and are usually white in colour.
The case or system fan are not usually temperature controlled but in some cases you can adjust the speed in the BIOS, the CPU fan however is temperature controlled.
Regards.
Jul 16, 2009 | VisionMan Computers & Internet
My Averatec wont turn back on. Its a 2300 series. 1.6 AMD daul 64x2 with 4 gig ram and 100 gig hard drive. It has done this befor and is a pain to get started again. Blue light in bottom right corner comes...
the fan in the machine collects dust and fuzz in side the housing. Most of it you cant see without taking the fan out. Mine had a lot of stuff built up and burnt out the fan.Now I have to find one I can afford. Thank you all for your help---Jeanie-Marie ps use a 5 or 6 volt power sorce to check the fan to see if it is working--the machine will not start if the fan does not work
May 04, 2009 | Averatec 3200 Notebook
Condenser fan torque question (F'aire side-by-side)
It should not need help getting started and will hurt a little to stop with one finger also it will cause the sides of the frig to get warm maybe even hot around the door try puting a small fan behind the frig with the back panel off till you can replace the fan that will help you know if that is causeing your cooling problem
Mar 30, 2009 | Frigidaire FRS26R4A Side by Side...
Help my computer wont start if I close my lid ....
It sounds to me that there might be a lose connection somewhere. The first thing to do is make sure that all cables are securely fastened.
When you say that your computer won't start when you put the cover back on and lay it on it's side does it respond at all when you hit the power button? Lights, anything displayed on the monitor, fan noise, etc.? Also when you leave the cover off is the computer laid on it's side like when the cover is on? does it work laying on it's side with the cover off?
MO
Jul 13, 2008 | Acer Veriton 3600GT PC Desktop
My computer wont go to windows xp when started up and it doesnt even go to any type start up screen
hi gllwymiller;
1.check all your connections
2.check monitor and cpu power
3.when you power on your cpu, do you actually hear the fan turning or see your power led light up?
4. what OS are you using?
5. Feel the rear fan or your CPU, is it blowing out air?
get back to me :)
Jul 01, 2008 | Gateway Computers & Internet
Wont start up
my wife has a presario that had a similar problem - it would boot up, then immediately shut down. I took off the side plate and blew off some of the dust inside. that worked for a couple of days then the symptoms returned. I took it apart again but this time I removed the cpu fan and the cpu heat sink. I cleaned all the **** off the fan and the heat sink and replaced it. this time it stayed on. I checked out the power supply. compaq installed a very cheap power supply - only 250 watts. a replacement power supply for the same machine but with an output of 300 watts is available. as soon as I can scrape up the change, I'm gonna change the PS
Jun 11, 2008 | Compaq Presario 5000 PC Desktop
Wont start
open the side casing of your cpu then try to switch-on, if you notice that the fan of your cpu rotates, the hdd led is lightng, the power-on led also lit then you heard a beep (one) sound there is no problem but your video card connection just loose
Jan 10, 2008 | Computers & Internet
Azza Orion 201 black/silver SECC Steel ATX Mid Tower Computer Case (Mail In $20.00 Expires 07... (CSAZ201) ATX Mid-Tower Case Logo
211 people viewed this question
Top Azza Computers & Internet Experts
David Payne
David Payne
Are you an Azza Computer and Internet Expert? Answer questions, earn points and help others
