Toshiba satilite series will not bootup. three long beeps,3 more long bips one short. what is this saying?
    Problem Solver:
  • 13 Answers
In my experience with this type of issue it can mean your hard drive is dead or something is wrong with your RAM if you have a spare hard drive on hand and ram replace the hard drive and ram and see if it fixes your problem
Posted on Jan 01, 2011
  • purejuss Jan 01, 2011
    ya, i tried that, with no difference at all. no screen no boot no nada! :(
    I did find something stating it was a "grounding out" problem.
    i have no idea where 2 start 4 that. i hate having to go "repair shop"!!!
    still searching...
Salut J'ai un Compaq Evo, à
can you post a question
on English?
you can see, just English here so...
good luck
or go to real HP and ask.,
https://h30434.www3.hp.com/
Jun 07, 2017 | Compaq (283983-001) Motherboard
My Toshiba X200 doesn't show any image.I've bought a new motherboard, but still no image appears.The tech that told that the problem was with the motherboard (that was supposed to be burned).Now he tells...
enable what? BIPS? never heard of it in the last 10 years, are you sure you are dealing with a PC tech there?!
Have you tested that the RAM on the computer IS OK?
Have you tested that the Video card on the machine is OK?
has any real troubleshooting been done on the machine?
if he just told you the motherboard was burned without doing any other testing you are dealing with a fraud.
Nov 07, 2010 | Computers & Internet
When I start my computer its only says bip bip bip
Three beeps indicates that there is a memory error. Take the system memory from the motherboard and clean the brass contacts on the memory and also clean slots that the memory clips into. Make sure you clean all of the dust away from them.
Put the memory back into the slots and try turning the computer on. If you have more than one memory module put them back one by one turning the computer on after each try.
If it still won't switch on and you get the beeps you will be looking at new memory for the computer.
Regards.
Aug 05, 2010 | ASUS Computers & Internet
Satilite 1800 3 beeps no boot 1 long 2 short
That is a memory error. Remove and reseat the memory in your computer. If the error persists and you have more than 1 stick, try each stick separately to find the faulty unit. If you only have one stick, then the memory will need to be replaced.
Jun 30, 2009 | Toshiba Satellite 1800-S204 Notebook
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
Non si vede niente dal monitor
tre bip lunghi potrebbe essere un problema della tastiera.
Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
* Un bip = tutto funziona normalmente.
* Due bip = errore POST/CMOS.
* Un bip lungo ed uno breve = problema con la scheda madre.
* Un bip lungo e due brevi = problema video.
* Un bip lungo e tre brevi = problema video.
* Tre bip lunghi = errore tastiera.
* Lunghi bip ripetuti = errore di memoria.
* Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
* Continui alti e bassi bip = surriscaldamento CPU.
guarda anche questo sito
http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Dec 31, 2008 | Intel D945GCCR Motherboard
Cmos cheksum bad
From your problem description, it sounds like a corrupt BIOS and or a failing motherboard.
Due to the system age, I'd say cut your losses, salvage what drives are usable, and get a new (or newer) system
Dec 07, 2008 | Computers & Internet
Asrock K7S41GX "NEW" does not work :bip-bip-bip
3 beeps is a memory error. remove the memory and put it in the first slot.
also the memory replacement calls for ddr pc2700.
Robert
Sep 05, 2008 | Asrock K7S41GX Motherboard
Toshiba Satellite Pro m40 Will not bootup
Yes. Could be a clue to a hardware issue. There are different manufacturers of BIOS... some differences in what the codes mean.
Is it 4 short beeps or a combination of short and long?
A reference for the codes:
http://www.pchell.com/hardware/beepcodes.shtml#phoenix
Try removing and re-seating your memory card.
Jun 25, 2008 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
David Payne
David Payne
