Question about Kenmore Microwave Ovens
I have a Kenmore 87103 microwave oven an the cardboard that cover the vent has the ends gone so can I use any carboard to cover the vent?
SOURCE: Waveguide cover for Kenmore microwave
Try replacing the screws with larger ones. Maybe you ordered the wrong piece, if your microwave comes with a mica cover (A fine, square piece of mica) and you received a plastic one, you will need to get the right piece or adapt the one you received.
You can get the mica cover on any microwave service.
Posted on Feb 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: interior cardboard/foil piece fell off revealing small chamber inside oven--still safe?
This is the mica or plastic waveguide cover. It protects the waveguide and magnetron form grease and food particles.
Assuming you're going to scrap the unit, carefully clean the area around the outside of opening (watch for sharp edges) with a lightly damp soft cloth.
Then use alcohol or a hair dryer, etc. to be sure the area is dry.
Then you can use a couple of strips of clear packing tape to cover the opening and trim it with a razor blade so only about 1/4" or so extends out from the opening.
Note that I only recommend this procedure on an oven that is going to be scrapped. If the oven will see continued use, a new waveguide cover should be purchased.
Posted on Oct 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Set up Oster Microwave
No, that is the "waveguide cover".
It provides very important protection for the magnetron.
And always keep it clean according to your manual's instructions.
Posted on Jan 18, 2009
EwingElect
  • 276 Answers
SOURCE: What is the cardboard cover inside my microwave for?
It may not be cardboard - it may be a material called mica which is located over where the magnetron is located in the unit. This is a protective cover and if it is what I think it is, do not remove under any circumstances, otherwise you may render the microwave unsafe to use.
Posted on Mar 31, 2009
Illeagle
  • 525 Answers
SOURCE: IS MY MICROWAVE NOW UNSAFE TO USE - CAN I DO OWN HOME REPAIR?
It sounds like what you are describing is called a "waveguide cover". You can purchase a replacement from a local parts supplier, or on-line at www.repairclinic.com. It is very easy to replace.
Posted on Jun 30, 2009
Why is there a burn hole inside the oven, on the cardboard?
That's actually a mica "window" (cover) for the microwaves to come out. And it sounds like the magnetron started arcing and burned a hole in that cover. Either that, or some food (frequently spaghetti sause) got splattered on it, and the microwaves heated it up so much that it burned a hole in the cover. Does the microwave oven still work (heat)? Do you see or hear any arcing? If the microwave oven still works and there is no arcing, you can just replace that cover. Check SearsPartsDirect.com or RepairClinic.com.
Jul 10, 2014 | Kenmore Microwave Ovens
WHY DID MY MICROWAVE OVEN BURST INTO A FLAME AFTER 30 SECONDS ON HIGH POWER? TWICE. LMV1314B bought Jan. 2008
Actually you don't need to replace the microwave, you just need to replace the carboard piece or "wave guide" and replace the magnetron inside the microwave behind the cardboard piece. The magnetron will commonly arc out to the wave guide if the wave guide gets something that splatters on it. The repair isn't cheap because the magnetron costs about $200 and the wave guide is another $30 or so, but if you replace both these parts you should be good to go again.
The magnetron usually have 5 years warranty, however you need to speak with manufacturer itself for the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 23, 2011 | LG LMV1314 Microwave Oven
I have a 2004 Sharp R-1214 1100 Watt Microwave and the card like removable 3 x 4 inch plate broke (almost like cardboard) and it covered the vented opening. I don't have a users manual so I don't know the...
That's the waveguide cover you're talking about. It covers the opening in the side of the cooking cavity where the microwaves enter. The oven will work without it, but if you don't have the cover in place, food particles can get into the waveguide and cause problems. You can buy a replacement here.
Feb 07, 2011 | Sharp R-1210 Microwave Oven
On the inside top right side of the microwave there was a cardboard cover held on by 4 corner points. The cardboard has fallen out now as it has come unsecured from the points holding it in place. Is it...
That's the waveguide cover.
If your waveguide cover is burned or damaged, it will need to be replaced.
It provides critical protection for the magnetron.
You should be able to get Galaxy parts from the Sears site.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Galaxy/Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 06, 2010 | LG MS-0744Y Microwave Oven
For the sunbeam microwave sgb8901, do you take off the cover over the oven air vent? It's inside the oven on the right hand side- it looks like a rectanglar silver colored piece of cardboard.
I am also having this same problem i dont know the solution yet, but when you figure it out please let me know, or if i figure out i will repost =]
Aug 30, 2010 | Sunbeam SMW750 Microwave Oven
There is a round silver disk (seemingly made out of card board) that fell off. Can it be replace with another cardboard cut out in the same shape?
the disk is just a microwave diffuser but, it is made with a special foil do not put regular foil into a microwave for any reason; just glue the disk back on with ordinary glue
May 20, 2009 | Microwave Ovens
Mar 23, 2009 | Microwave Ovens
Kenmore Microwave stopped working.Mod# 87103
To the guest who wrote:
Aug 15, 2008- Won't run on start. the minute number flashes and same with the word TIMER on the top right.
Clock will change but won't start..
Did you ever solve this problem? I have the same one as of yesterday... this is a fairly new microwave, would hate to have to replace it so soon.
Jun 16, 2008 | Microwave Ovens
Feb 16, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
