Question about GE PFSS9PKYSS (285 cu ft) Bottom Freezer French Door Refrigerator
My GE Profile French Door Refrigerator is not cooling at all. The problem was noticed 2 days ago ll the meat in the bottom freezer thawed out, there is no cooling temperature at all. Also, on the display screen the temperature screen is reading OF on both side. What is the cause of this, and does this need to be gassed up for cooling? if so let me know. Please keep in mind i live in the Bahamas on the island of Freeport, Grand Bahama, and my appliance was bought in Florida at one of Home Depot Store.
dididsaythat
  • 291 Answers
SOURCE: GE GSS25KSWA
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Posted on Sep 04, 2007
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 47 Answers
SOURCE: GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Posted on Nov 20, 2009
SOURCE: Temperature display lights do not
I have the same problem as well, although the temperatures seem to be holding, you just can't read them.
Posted on Dec 30, 2009
GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
Put the old board back in. See what it does, from your post, sounds like it was working correctly.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
Ge profile refrigerator not cooling
there is a fan that brings the cool air from the freezer to the fridge. make sure thatit is working and that the vents for it are not blocked or frozen
Nov 10, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
Have a GE side by side gsh22sgress unit. Child left freezer door open. Unit ran for days (in non-occupied appartment). Meat thawed. Cleaned unit inside with mild soapy mix. Unit runs but will not cool...
Open door let too much moisture into refrigerator. (The cooling coils, behind the back wall of the freezer compartment, are blocked with frost) If you unplug the refrig for a day or so it will work again, or you can take the back wall out from inside the freezer and melt the frost with a hair blower.
Aug 21, 2010 | GE GSH22SGRSS Side by Side Refrigerator
GE Profile PFSF5NJW French door Bottom freezer. Freezer is fine. Refrigerator at 60 degrees. Unplugged for two days to thaw any possible freeze up. Refrige still at 60 degrees.
If that is what happened after plugging back in still no change in temperature I recommend you call someone you can trust. Trust is about asking too much these days. You refrigerator does not need to run at all until I or someone can find the problem. If someone there would like the challenge and knows how to use a multi-meter let me know. Thanks, Sea Breeze
Nov 21, 2009 | GE Profile PFSF5NFW Bottom Freezer French...
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Ge profile french door bottom freezer the freezer temp has been fluctuating form 4 t0 14 degrees have been using turbo cool control to reset drops the temp but by the end of the day its back up
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 28, 2009 | GE Profile PFS22MS Bottom Freezer French...
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PFSS9PKYSS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
210 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
