Question about Casio GW810D 1 Digital Shock Watch
How do you adjust the band on a casio gw810d - Casio GW810D 1 Digital Shock Watch
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
The schlatter.org solution is for the other type of casio band I've run into.
The wristband with the arrows has a fine pictorial solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band
Basically you use a very very fine poker to poke the pins out in the direction of the arrows.
NOTE: you can't poke them out if you will drive them into your work surface, so think about that before you start.
Posted on Feb 02, 2008
SOURCE: how to adjust metal wrist band on casio watch?
Take it to walmart or any store with a jewelry section, they'll fix it
Posted on Sep 20, 2008
SOURCE: Casio watch band adjustment
Check the Citizen web site: http://www.citizenwatch.com/Technical/English/Service/pin1tube.pdf
You can skip the part about removing the split tube. Instead of their pin pushing tool, I used a short piece of straight pin held with long-nose pliers while I squeezed using medium sized channel-lock pliers. A helper to hold the watch would've been good.
Posted on Dec 26, 2008
  • 4 Answers
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
Casio GW810D I have changed the battery, the display is now running but none of the buttons are functioning. Have I missed/lost something. Any help is appreciated.
you need to do this Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs
Feb 12, 2013 | Casio GW810D 1 Digital Shock Watch
How do I adjust the band on a Casio AQ 160 watch?
try this link below there are several diffarant band adjustments that may help you
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Nov 02, 2012 | Casio Watches
MANUAL CASCIO GW8100
In addition to small6363 solution,on the back cover there is a 4 digit number
in a rectangular frame.This is the module (mouvement mechanisme) number.
You put this number where "Module No"is written and then you click "Search".
May 15, 2012 | Casio GW810D 1 Digital Shock Watch
I'm unable to set up the time on my watch
Here is the complete instruction on how to set up your watch step by step inclusing visual, click on the link.
I hope this will be able to help you.
thank you for choosing fixya
Mar 06, 2011 | Casio GW810D 1 Digital Shock Watch
How do you shorten the metal band to make it fit your wrist?
If you do not know how to shorten the strap, the simplest answer to your problem is to take it to your nearest watch shop. Most of them will be able to do it for you for a small charge.
Dec 11, 2010 | Casio GW810D 1 Digital Shock Watch
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    How do you adjust the band?
    Read my tips and tricks. Watch band is called bracelet as well.
    Jan 23, 2010 | Casio Wave Ceptor Atomic WV300DA 7A...
    Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Adjust the band links for Casio MTP4500D-1AV ( model #4755 )
    You can tap out the pins in the band with a small punch. a ground off needle may do it
    Jun 22, 2009 | Casio MTP4500D 1AV Analog with Chronograph...
    Band size adjustment
    Try entering Casio`s page and search the manual.
    Jul 29, 2008 | Casio AW80-7AV Wrist Watch
    Casio GW810D 1 Digital Shock Watch Logo
    159 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
