Question about Sony Playstation 3 (PS3) Console
My playstation 3 system keeps trying to read the disk but does not show the icon i have tried restoring the system cleaning the lens with a cd lens cleaner please help
  • 492 Answers
I am assuming you are saying that either your PS3 is unable to read the disk when you pop it into the console, or it's constantly reading it while you are playing the game. If neither of these resemble what is happening, press and hold the power button on your PS3 for about ten seconds. When it beeps a couple of times, release it.
First off, restoring the PS3 and reformatting the Hard Drive are two different things. If restoring the PS3 didn't work, you can always try reformatting. You will lose all your saved states but it could fix your problem.
If it's just trying to read your disk when you're playing a game, this is common. You'll likely see the HDD indicator lighting up several times while you are playing a game. The days of looking for a save point are over. Your game will always be sending information to the HDD when you pass certain checkpoints or areas of interest so that should you get a Game Over, you can resume from the last checkpoint.
Beyond that, I would call SCEA (1-800-345-7669) as it could be a defected piece of hardware. Maybe you covered the air vents with something and it got too hot.
Posted on Jan 01, 2011
My nba 2k11 freezes in my original ps3 what should i do?
Make sure the disk is clean, try using a optic lens cleaning CD, Check for any imperfections in the disk, and last you could try a system restore.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
My ps3 will not show i have a disk in the console. I tried cleaning the lens still no disk. Help?
The problem is that the lens of your ps3 is either dirty or weak that it can no longer read any disc, i advice that you get a lens cleaner to clean the lens of your game, if after cleaning, problem persist, replace the lens on your ps3 so that your ps3 can continue to function as it use to function before.
Replace the lens on your ps3 and you will see that it will start reading discs.
You can also try the below procedure before replacing the lens,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 13, 2010 | Sony Playstation 3 (PS3) Console
Do not read the disc
You can also try the below procedure,
Take care.
Jul 21, 2010 | Sony Playstation 3 (PS3) Console
Console will not read games when inserted
Boot up to Diagnostic screen (google how) and try to restore file system. Next try to reformat hard drive and restore PS3 system. Next you can try to clean the lens. Lastly, listen closely when the disk is inserted (if the above have not worked), if you here a "studdering" noise, then you probably need a new lens.
VEry easy to install.
I have posted compatability charts, etc. numerous times on here, lookem up.
Let me know if you need help with the install. EZ
May 19, 2010 | Sony Playstation 3 (PS3) Console
My playstation all of a sudden will not play a game or dvd or music cd.it shows everything for internet usage but will not reconize a cd will not even show a disk this is for ps3
This problem is usually associated with the Bluray drive or more specifically the optical laser on the drive which is failing to read the disk. Sony charge $150 for this repair if the console is outside warranty.
You could try cleaning the lens on the laser as this can work sometimes but this requires you to open the console and most often the lens is faulty and needs to be changed. For more information on the lens and how to access it either to change it or clean it please see this FixYa Tip.
Thanks for using FixYa
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
Not reading disks
The first thing to try would be a lens cleaning disc. The laser could be dusty preventing it from being able to read the disc.
You can get a lens cleaning disc kit at almost any store that sells dvd's and cd's.
Note: Do not spray compressed air directly at the laser.
You can however blow air through the vents to try and remove any dust from inside the playstation.
Try these two things, if it doesn't work or you have already tried these ideas post back and share the results. Thank you for choosing Fixya!
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
Playstation want read any games but doesnt say disk error
You might have a bad lens right now. Try to use a CD lens cleaner to clean your lens. If that doesn't help, you might need to have your PS3's lens replaced. Sorry bro, this happened to me too. its really sad..
- HotRatchet
Dec 14, 2009 | Sony PlayStation 3 40GB System
Hello my Dell Studio 1435, it can read CD but not reading DVD... it give noise when i put DVD..
Try using a good quality DVD cleaner first. The lens for cd/dvd are different so one may work if the other is dirty. If cleaning does not work then the dvd lens may be out of alignment or broke. With today's prices it is cheaper to replace the drive $30-40 than try to repair it. Hope this helps.
Sep 11, 2009 | Dell Studio 15 Laptop
My blueray cd is not reading
when putting disk in check by listening if you can hear the disk spinning at high speeds or a clickin noise, this means the laser is having trouble reading disk,try cleaning with a cd laser cleaner you can get these from comet argos pc world etc,if this does not work the laser may have burned out,one of the main faults with playstation and xbox is the fans that cool down the system also draw in dust through the vents wich inturn soil the laser lens hope this helps andy
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
