Question about Samsung Washing Machines
Red lock symbol displayed, I cannot open the front loading door, how do i open?
  • 1,531 Answers
You should be able to press the signal and soil level buttons for two to five seconds and it should ulnlock
Posted on Jan 01, 2011
Lock symbol is on but the door won't open
Hi Maire,
The door cannot open when the lock symbol is showing. Check your owner's manual for fault finding tips.
Aug 30, 2015 | Hotpoint Aquarius WD640 Front Load...
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
Power going to washing machine but wont start
The door (interlock) is likely faulty & needs to be replace.The door probably doesn't lock at all because the (interlock) is not energizing.
May 30, 2010 | Zanussi ZWF1230W Front Load Washer
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
The water switch to the washer wasnt turn on due to no water going to the washer from the hose it was blinking red H symbol I tried to cancel load to restart and machine stays on and wont start new cycle...
Just unplug the washer and wait a couple of minutes before you plug it back in. That should clear the code and let you get the door open.
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door opens when it should be locked, won't start wash cycle,
Power off the wall mains, plug off. Try some WD40 on the lock mechanism on the machine, not on the door. Open and shut few times. Check to see the wires are in place, re the door mech. If it still does not work you probably have a broken latch, which you can replace yourself.
Sites for spares:
RepairClinic.com
AppliancePartsPros.com
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Nov 07, 2007 | Washing Machines
Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Aug 23, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
665 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
