Printer runs put does not print - Office Equipment & Supplies
  • 51 Answers
Check comunication with computer(cable).uninstall the driver and reinstall.check port setting.
Posted on Jul 08, 2008
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Not printing black on right side of doucements
Run the PQ Troubleshooting diagnostic
Check out the BLACK page.
You can also run the Disable Cartridge Check diag.
This test will enable you to pull all the cartridges out, and put the black into any other slot. Then print the Configuration Page and see if the problem follows the black cartridge. If it prints good this way. Put the Cyan into the top slot(black), print the config page. If it prints bad, it's not the cartridge it's the printer.
I think that replacing the Black Cartridge should solve your problem.
Jan 05, 2011 | HP LaserJet 3600dn Printer
La impresora aunque me indica que los cartrige estan bien no imprime,trato de hacer una imprecion de prueba y tampoco funciona.
Hello.
Inkjet printers have the major disadvantage of having often having clogged print head cartridges that can be very annoying in the long run. Though advanced inkjets might possess their automatic print head cleaning process, this might not work every time. The problem might be because a layer of
Using a syringe and some alcohol to unblock the holes can be very effective.
Step 1: Remove the cartridge from the printer
Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Hope this resolves your problem.
Nov 27, 2010 | Lexmark Z845 InkJet Printer
How to clean cartridge
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
  • Remove the tank.
  • Connect a hose directly on the inlet ink.
  • Locate the sensor of reservoir and press it to make as if a cartridge is available.
  • Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
  • Replace the tank up and do a test print.
  • Repeat the procedure several times if the nozzles are clogged.
Using a syringe and some alcohol to unblock the holes can also be very effective.
  • Step 1: Remove the cartridge from the computer
  • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
  • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
  • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
  • Step 5: Run some test prints before using the printer normally.
Apr 03, 2010 | Lexmark Inkjet Z517 Photo Printer
Full cartridges = empty :S
Solution 1
* Remove the tank.
* Connect a hose directly on the inlet ink.
* Locate the sensor of reservoir and press it to make as if a cartridge is available.
* Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
* Replace the tank up and do a test print.
* Repeat the procedure several times if the nozzles are clogged.
Solution 2
* Step 1: Remove the cartridge from the computer
* Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
* Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
* Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
* Step 5: Run some test prints before using the printer normally.
Jan 02, 2010 | Epson Stylus 880 InkJet Color Printer
Instructions to clean print head of Canon iP5000 printer, please.
Try first with cleaning tests on maintenance mode.Make sure all cartridges are not empty.If not help try manually cleaning.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.
Nov 23, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 12, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My Canon iP3500 printer is printing pictures that are fuzzy with white lines in them & apinkish-blue color. I replaced all the cartridges. How do I clean the printer heads?
Oct 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Printing quality poor
Try this one, Turn on the printer, Take out the inks, remove the
printhead, put back the printhead make sure it will snap and you hear a
click, put the inks back, wait for the printer to initialize, Press the
Menu button, look for Calibrate printer, then print calibration page,
then scan it after. Load a regular paper. Then try to print a demo page
If
same problem persist call this no for further assistance 1800 421 6699 Thanks
Aug 14, 2009 | Kodak ESP 5 Printer
HP C6180 responds to print but puts out blank pages
All I had to do was clean the print head. Try these steps: Press setup, scroll down to tools. Select clean printer head. The printer will run a clean cycle and then print out a diagnostic test page.
Jun 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
112 people viewed this question
k24674
jasbo
jasbo
