Question about Kenmore HE2 Plus Front Load Washer
Washine machine locks up wont open and has an error code L35 or F35 cant remember which letter seems like this only happens when im trying to use steam
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure. To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. The analog pressure sensor is shown in the second image below. You can see the location of this component in the first image. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component. If you find no problems, then you will likely need to replace the component.
Posted on Jan 01, 2011
My daewoo washin machine shows error code OE & it wont work actually whats the problem ? tq
Error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. Remove the suspected hoses and clean out. Replace and your good to go.
Nov 21, 2016 | Daewoo Washing Machines
My washer wont lock and now it does not spin why
The door has to lock as a safety to allow the machine to run. There is a switch on most locks to tell the machine to power the motor.
I would guess the lock solenoid has failed, or something has happened to the latch for the door.
Sep 16, 2012 | GE WBVH6240F Front Load Washer
I cannot open my Noble safe with the code I had. It seems that my code is gone and I don't find the key to open the safe. What can I do ? songa
I cannot open my Noble safe. I havent used it for 1 year, it has no battery and cant open it with my key. I cant remember the code, but i wont be able ti use it with no batteries.
What can i do
Feb 23, 2011 | Safe International Digital Electronic Safe...
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
Code f35 and sud on washer machine/whirlpool duet front loader
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Error Code F35
we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
Kenmore HE2 Plus Front Load Washer Logo
135 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
