Question about Maytag MDE2600 Electric Dryer
Maytag Neptune dryer timer won't stop
We've had a Maytag Neptune electric dryer for the past 8 years. It is model MDE 4000AYW, serial number 31437690YW. We've had only minor problems with it until recently when it stopped shutting down after drying was completed. The timer justs cycles around and around and never stops. The only way to stop the dryer from working is to open the door and even then the timer keeps cycling around. Is this simply a situation where the timer needs to be replaced? If so, is that a do-it-yourself type repair or something we'll need to call for a repairman? Thanks, Ken.
  • 1 more comment
  • Steelie2 Jul 08, 2008
    Thanks for the feedback and link on how to replace the timer. However, I would first like confirmation that from my problem description it is clear that the problem solution is indeed to replace the timer.
    Thanks to both of you for promptly commenting on my Maytag Neptune dryer timer problem and the solution. Ken
  • Steelie2 Jul 16, 2008
    My replacement timer switch arrived yesterday so I'm now ready to replace the defective timer switch on our Maytag MDE2600 electric dryer. What is the proper way to get access to the timer switch to remove and replace it? Is it nothing more than disconnect power and remove the four screws on the back of the panel?
    Thanks, Ken.
    Sergeant:
    Champion:
  • 250 Answers
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Posted on Jul 08, 2008
    Master:
  • 788 Answers
Here's a link to a great site to purchase the timer, there is a diagram of how the part goes into the machine also. Should be fairly simple to replace yourself.
http://www.partselect.com/xq/aspx/Inventory.82146/qx/PartDetail.htm?SourceCode=1
  • Dean Joly
    Dean Joly Jul 08, 2008
    The timer does all the thinking in a conventional dryer, it controls the motor, fan, and element. There are no other circuit boards in your dryer. There is no doubt that if your timer doesn't stop that this is caused by the timer and nothing else.
  • Dean Joly
    Dean Joly Jul 17, 2008
    Yes, remove those four screen and the panel and you will clearly see what you need to do to get the timer out. You will have to pull the knob off the front or course.
  • Maytag Master
  • 19,396 Answers
You will have to replace the timer control
  • 1 more comment
  • Ginko
    Ginko Jul 08, 2008
    Here you can buy the replacement
    Here more exploded views
    You can also ask them the service manual, if you want to do the job by yourself it may be useful.
  • Ginko
    Ginko Jul 08, 2008
    It is not a very difficult job, particularly if you replace the whole panel. Remember safety rules and work with power unplugged, possibly get the service manual and follow instructions and wiring diagram.
  • Ginko
    Ginko Jul 08, 2008
    If you do not feel sure call a technician, DIY always involve some risk.
SOURCE:
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune MDE5500AYW will not stop unless it is unplugged
if you have it on time dry and it counts down but won't shut off you most likely have a bad computer board,part number 33003028 and it's around 180 dollars.on older machines it would be a problem with the timer not going to off but you have a computer board in your machine and it takes the place of the timer and other functions,just about everything runs through the computer board.
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer MDE 6700AZW Stops working
try a simple test before you try to gain axcess to the console parts unplug the power cord 1 min plug back in and put in time dry not auto or it will time out quickly without wet cloths see how it does and if this not solve you problem repost with model #
Aug 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Need Manual for Maytag Electric Dryer
Go to Maytags website and under support you can usually get an online version of the manual if you know the model # of it.
Jul 26, 2009 | Maytag Dryers
Can't figure out how to get the top off
http://www.pcappliancerepair.com/model-display.php This one looks like a real puzzle. Open the door and look for screws holding the front on, the top seems to lift up once something is released.
Apr 26, 2009 | Maytag Neptune MDE4000 Electric Dryer
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Mar 31, 2008 | Maytag Neptune MDE5500AY Electric Dryer
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag MDE2600 Electric Dryer Logo
1,378 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
