Question about Harsper HL-3000 30 in. LCD Television
Hi, have a Harsper L401V LCD 40 inch TV. It has suddenly stopped working. The backlight appears OK but when starting we get the green light hard on, then it flashes 6 times, then amber once, then back to green but no screen?
  • Harsper Master
  • 6,993 Answers
This seems to me like a power problem. It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Jan 01, 2011
Samsung un40eh5000f led backlight don't work i replaced power supply and main board still no luck
Troubleshooting the Samsung LED TV Model UN32EH4003 ...
? 2:46
https://www.youtube.com/watch?v=2TImpsUnGtI
Jun 25, 2013 - Uploaded by George Droukas
Samsung TV troubleshooting, In this video you will be able successfully ... where can I buy the power supply board? the ledlight doesn't light up so it .... The second port was still fully intact but also not working, I was able to get it .... which turns onbacklight (BLU_on) and turns on the power supply (PS_on).
Samsung UN40EH5000 Review; 40-inch LED TV, (also ...
reviews.lcdtvbuyingguide.com/samsung-lcd.../samsung-un40eh5000.ht...
The EH5000 is Samsung's lowest end line in the larger size LED backlit LCD TVs for... 60Hz refresh rate doesn't handle judder sports programing and gaming as ... take advantage of the resolution, giving you more work space on the screen.
Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV
www.amazon.com/Samsung-UN40EH5000.../B00723...
Amazon.com, Inc.Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV (2012 Model) ... Samsung didn't advertise this (or maybe its just my TV), but I have absolutely NO BACKLIGHT BLEED...... Hope that helps you find the settings that work best for you. ..... Game Modedoesn't really do anything except make the picture darker and less ...
Jan 05, 2016 | Samsung 40-inch LED TV - UN40EH5000FXZA...
The tv suddenly goes black and the power light blinks red
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
Hi guys, I have got a spot on my Sony 40" LCD TV which i got when one of my cat urinated on the TV. its about 4 inch in diameter and is on the bottom right corner of the screen. Now my quest
moisture and electrics dont agree with one another. Could try
isolating from the mains and spraying lightly with car windscreen
de-icer (isopropanol) wipe off any excess and leave in a warm spot for
a few days....Might work if you are lucky
Oct 27, 2014 | Sony "BRAVIA EX 400 Series 40-Inch LCD TV,...
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Viewpia lcd tv backlight not working
Measure the input voltage to back light inverter board, from the main power regulator board. If it is found OK, replace back light inverter board.
Jul 27, 2012 | Televison & Video
My sharp aquos lcd tv 32 inch usually gets hard time in turning on coz once a brownout occurs and when i turn it on only the green light appears without pictures so i have to unplug it on and off as...
Sounds like you have bad capacitors somewhere in the TV. If none of them are bad, you could also have loose grounding screws on the inverter shield. It is common for this TV and simply retightning them will keep the backlight on again.
Mar 23, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Harsper HL-3000 30 in. LCD Television Logo
42 people viewed this question
Top Harsper Televison & Video Experts
Electro Med Services...
Are you a Harsper Televison and Video Expert? Answer questions, earn points and help others
