Question about Kitchen Ranges
Screen is not working. clock is flashing with PF
  • 312 Answers
Hi Matt,
PF stands for Power Failure. Try resetting the time on the clock. If you do, it should allow you to use the range properly.
Hope this helps.
Have a Happy New Year,
Mark
Posted on Jan 01, 2011
  • 1,531 Answers
This is a power failure code.Cheeck the main power supply and make sure the circuit breaker is ok then you should be able to press the clear off key and see if the unit will reset.
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: pf on indicating area reset clock, oven light
Make sure the range is not plugged into a GFCI outlet. This could be a sign of a bad ground connection some place or a bad solder connection on the control board. Not easy to locate sometimes and may require a new control board.
Eric
Posted on Dec 19, 2009
My oven is always flashing PF what does that mean
"PF" stands for Power Failure. There should be a reset procedure in your user's manual. I cannot specify this since you don't give the manufacturer or model number of your oven.
Jun 24, 2015 | Ovens
Help me with my Frigidaire Es510 Control Self cleaning,Oven with deep well style cooktop It has the time flashing but will not respond and it also has PF on it
The CLOCK pad is used to set the clock. The clock may beset for 12 or 24 hour time of day operation. The clock has beenpreset at the factory for the 12 hour operation. When the range isfirst plugged in, or when the power supply to the range has beeninterrupted, the timer in the display will flash with power failure "PF"
Instructions:
To set the clock (example below for 1:30):1. Press the round "CLOCK" button. "CLO" will appear in the display (Fig. 2).2. Press the round "1" "3" "0" pads to set the time of day to 1:30 (Fig. 3)."CLO" will appear in the display. Press the round "Start" button. "CLO" willdisappear and the clock will start (Fig. 4).
Oct 10, 2011 | Kitchen Ranges
Flashes PF on display and smells funny
I recall from manuel that PF on screen means there was some type of power failure. If clock time is set it should go away.
Feb 11, 2011 | Frigidaire PLES389D Electric Kitchen Range
Pf code flashing on oven
PF = Power failure.
Usually all you have to do is press stop / cancel, then Clock then CLOCK again. After the time is set your microwave should work normally again.
If this does NOT correct your problem I need a complete model number in any future responses.
Thanks for choosing FixYa.
Kelly
Jan 04, 2011 | Microwave Ovens
My microwave shows PF on the screen and none of the buttons are working, not even the timer button. How to solve this problem ?
PF = Power failure. Try and push the clear or cancel button (or start, or clock etc) You may have missed one. If that doesn't work try and unplug it for 10 seconds or so and retry.
Sep 14, 2010 | Microwave Ovens
Pf??
PF means power failure.
For short outages the clock may still have correct time
(there is a battery backup for that), but the PF will
be displayed. Setting the clock will clear the PF
indication.
Press 'clock set-start' button, (under clock display)
enter time with numeric keypad,
press 'start' button. (to right of clock)
Jan 03, 2009 | KitchenAid KESC308LSS Electric Kitchen...
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
