Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
My picture settings are fixed and i would like to adjust them
  • 1 more comment
  • dferguson103 Jan 01, 2011
    it will not let me select opc or display
    What you suggested did not fix my problem.I cannot access opc or any other adjustments such as picture etc....
    your solution did not work. I cannot access opc or picture etc...
    Top Expert:
  • Sharp Master
  • 74,198 Answers
Hello
To select the picture to adjust to your taste, you jhave to switch off the [OPC], function first, if it is switeched to "ON".
To do this
[1] Press MENU button to display MENU on the screen and then press RIGHT or LEFT button to select "Picture".
[2] Press "UP" or "DOWN" button to select "OPC"
[3] Press "right" or "left" button to seelct "ON" or "ON: DISPLAY".
When it is off:_ The backlight is fixed at the value set in "Backlight".
When it is "ON" :_ Automatically adjusts backlight.
When it is "ON:Display" : Displays the OPC effect on the screen while adjusting the brightness of the screen.
After setting "OPC" to off position, you can adjust the picture according to your taste.
[1] Press "Menu" button to display "Menu" on the screen.
[2] Press the "right arrow or left arrow" to select picture.
[2] Press "up arrow or down arrow" to select the specific adjustment item.
[4] Press "right arrow or left arrow" to adjust the parameters of the desired item.
[5] Press "MENU" to exit.
For resetting picture adjustment items to Factory settings, press "up or down" arrows to select "RESET" and press enter. Then press 'Right of Left" arrow button to seelct "Yes", and then press 'ENTER".
Select "Advanced" and then press "Enter" to set "Colour Temperature", "Black", "fine Motion Advanced","3D-Y/C", "Monochrome", "Film mode", or "range of OPC [if OPC is used].
Adjust "Tint" to get better skin tones.
OK
Posted on Jan 01, 2011
  • The Knight
    The Knight Jan 01, 2011
    Hello
    I've given these instructions from the user manual of your TV itself. If it does not allows you to go to its menu, there must be some firmware corruption. You just go to its manual and try to make it reset and try the above processes. Resetting will maked all your V-Chip adjustments out, and you have to reset it after. OK
  • The Knight
    Hello
    To reset the Tv to factory settings; explanations are given its maual on page 35. If you haven't the manual I hereby quotes it for you.
    It says
    If complex adjustments are made and the settings cannot be restored to normal, you can reset the value to factory level settings. For that follow the instructions given below.
    [1] Press MENU to display MENU on the secreen.
    Then press Right or Left arrow to select "Setup".
    [2] Press UP or DOWN button to select "Reset" and press ENTER.
    * If you ahve already set a secret number; input the four digit secret number here.
    ** "RETURN TO FACTORY PRESET VALUES " displays on the screen.
    [3] Press Right or Left button to select "YES" and then press ENTER.
    '"NOW, TV WILL RESTART AUTOMATICALLY. OK?" --will display on the screen.
    [4] Press right or Left button to select "YES" and then press ENTER.
    * "Now Initializing...." displays on the screen and blinks.
    * After reset tis completed,the power shuts OFF and then come BACK again. The screen will have returned to its original settings.
    Now you can adjust the picture adjustments and all other things. OK
What is the OPC light?
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Feb 04, 2016 | Sharp Aquos Televison & Video
Vizio picture
It looks like your picture is zoomed, that control should be on your remote. Or change your picture ratio. Tints are all messed up. I would bring everything back down to black and white and start adjusting back up. To do this you have to be in picture mode custom (your pic shows your in standard mode). Everything else is preset for you. Go into all your settings and make adjustments. I also own a Vizio. It took me several attempts to adjust the picture to my liking.
Mar 17, 2014 | Televison & Video
No picture, only colored vertical lines
Settings. It sounds like the convergence. It needs to be adjusted. Have had this problem before. A lot of people actually throw there TVA away because they have this problem and they think its broken, when its usually just a simple fix of adjusting the convergence. You have to make sure the little box, on the convergence settings is in the middle. Hope it fixes ur problem. :)
Dec 30, 2012 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
Zenith TV has me seeing red.
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Mar 16, 2010 | Zenith B25A10Z 25" TV
I have a blue rectangle in the bottom right corner
I had the same problem. I fixed it by "resetting all settings" in the Picture Adjust menu.
1)Press Menu
2)Right arrow a couple times to select the Picture Adjust menu (icon looks like a gear)
3)Down arrow to select "Reset All Settings" at the bottom of the list
4)Right arrow to tell it to do the reset
Voila!  It fixed my tv.  I hope this helps you.
Sep 24, 2009 | Televison & Video
Cant adjust picture with remote
If you are using the The HDMI port "dynamic Fixed" is all the picture setting options you get. It's some manufacturers preseleted settings that you can not adjust, mine does the same thing.
Oct 19, 2008 | Sharp 65DR650 65" Rear Projection...
Fixing Tilt
YOU PROBABLY TOUCH THE SCREEN VOLTAGE ADJUSTMENT LOCATED ON THE FLYBACK TRANSFORMER. BECAREFUL ADJUSTING IT LPUS IT IS HIGH VOLTAGE USE A PLASTIC ADJUSTMENT DRIVE.
THANKS DOCTOR VIDEO
Apr 24, 2008 | Panasonic CT-27SX11 27" TV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
348 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
