When power on show error 07.010.438160 - Office Equipment & Supplies
  • Anonymous Oct 10, 2008
    I have the same problem, & xerox`s assistance cost about de 50%& of price of printer + another cost bigger than price of printer if change printer head!!!!!
    President:
  • 2,072 Answers
You have a problem with either the process drive motor not being timed. Or the print head is not pivoting forward and backward or side to side.
There is a stainless steel print block on the left lower frame about mid way back. It may have ink leaked into it and now allowing the head to pivit properly.
The print head wiper may be stuck to the print head, if the printer is not shut down properly or you had a power outage it may be tacked to the print head.
Posted on Jul 08, 2008
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Oct 26, 2012 | Konica Minolta Bizhub C 353, Bizhub...
Shows colour registry error + hooks when printing and shows power off on
Aug 06, 2012 | Gestetner C7417 Laser Printer
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Cannon gp200 - we have an error code 803-switch power on and off
we have an error code 000 - the message is switch power on and off- we tried this and the same code/message shows again please answer
Apr 03, 2009 | Canon Office Equipment & Supplies
87 people viewed this question
k24674
jasbo
jasbo
