Question about Sony DUALSHOCK3 Wireless Controller PS398053
My controller won't stop vibrating. - Sony DUALSHOCK3 Wireless Controller PS398053
  • 492 Answers
This could be one of two issues:
A) Your controller isn't real, was manufactured somewhere in China as a scam to get your money. You bought it off the Internet and got scammed.
B) If it's actually a Sony controller, it could be a hardware defect. It wouldn't just vibrate unless the PS3 Game told it to... If it's still vibrating, try letting the battery die completely, then plug it in. If it's still vibrating, call SCEA (1-800-345-7669).
Posted on Jan 01, 2011
IPhone won;t stop vibrating ,blank screen won';t charge help ??
If phone was dropped or got wet, it needs to be taken to a tech ASAP. Try restoring it, putting the device on DFU mode.
Nov 01, 2014 | Apple For iPhone 4/8GB LCD Screen...
Have 02silverado4x4 when I apply brakes at low speed pedal won't go down and vibrates abs light is on
brake fluid comtaminated, all your seals are probably shot, @ master cylinder, wheel calipers, etc., the combination valve is stuck ., Is your fluid black ? Bleed entire system, completely, see if that helps, otherwise, good luck
Jan 28, 2013 | Chevrolet Silverado 1500 Cars & Trucks
My afterglow ax-1 xbox 360 controller won't stop vibrating when plugged in
Did you try plugging it in to another USB port? This sounds like a problem with the USB cable of your controller or the USB port on your PC. Try bending the cable near the plug etc. and see if it makes any difference. If not you'll be better off buying a new controller unless its still under warranty.
Nov 15, 2012 | PDP Afterglow AX1 Controller for Xbox 360
Crazy fit won't stop vibrating when it has power to it
1) You must test the switch stop.
see the diagram for to fix it.
May 10, 2012 | Sunny Health & Fitness Crazy Fit Massager
Changed rotors and pads on volvo s80 2001 but strong pulsating continues when braking
Abs control valve it's a big unit under hood with all the brake lines going to it then out of it to calipers. It has wire harness connector un plug it and try brakes aware that abs won't work but brakes will operate be careful until this is verified if pulsing stops that control valve has a problem. My advice is to never buy another Volvo I won't I had one
Apr 02, 2012 | Volvo S80 Cars & Trucks
My baby monitor won't stop vibrating!! about every five seconds it vibrates 7 times.
I had the same issue, I called Samsung, they where great help got right on the line with them. The issue is on the actual camera for the monitor the sensitivity dial is set to high, just lower it and you should be good.
Aug 01, 2011 | Samsung Wireless Security Monitoring...
Our Samsung SEW-3030 won't stop vibrating. How do we get it to stop?
Adjust your sensitivity dial which is located side of your monitor. It might hard to find suitable sensitivity, but once you find, it will not vibrating.
OR
You can just put sensitivity dial all the way down to turn alarm function.
Hope this helps!
Jul 30, 2011 | Samsung Wireless Security Monitoring...
Have 2002 outback with bad vibration on gear , the engine runs good , I did replaced all mounts , still the same problem, help please.
I concur with anon263. When we replaced driver-side axle with an aftermarket one, the vibration was horrible. Most people around me would not believe that was the cause, but as soon as we replaced it with a Subaru OEM rebuilt axle, the vibration disappeared. Get a new one from Subaru if you can afford it. Here's hoping the rebuilt one will last, although some out there have said that it may cause other problems down the line, most likely just because it won't last as long as a new one. The aftermarket axles, with exception of MW, are off just enough in their designs and spline size to allow harmonic vibration to transfer from the engine to the wheel and then your steering wheel when you are stopped at a stop sign and still in gear. The vibration usually goes away when you put it in neutral or park. In my case, I even thought I detected some strange vibration when driving.
May 30, 2011 | 2002 Subaru Outback
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
Sony DUALSHOCK3 Wireless Controller PS398053 Logo
649 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
