Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
I have a refrigerator made by frigidaire model #GLHs37EHsB7 I need the correct temperature setting for the freezer and refregerator.
fridgetech
  • 473 Answers
SOURCE: food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Posted on Oct 14, 2007
  • 1462 Answers
SOURCE: Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Posted on Sep 25, 2008
SOURCE: Freezer temperature won't get cold enough.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Posted on Jan 18, 2009
SOURCE: refrigerator not keeping cool
Your coils could be clogged with debris. i had the same problem. You can go to home depot and get a specific brush that you can use to clean out the coils. They are either behind the fridge, or under the fridge. Do it on a regular basis, cause that can cause the compressor to burn out. I am not an expert, but that worked for me
Posted on Feb 13, 2009
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
Model XRSS465BB Refrigerator - what is the correct refrigerator setting to avoid frozen vegetables? Also what is the correct deepfreeze setting?
usually meduim setting is good'
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Jun 14, 2015 | Amana Refrigerators
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 11, 2015 | Frigidaire Refrigerators
What should the freezer temps be on Frigidaire Galaxy models
Good Afternoon Friend,
I understand you want to know what the freezer temperature should be set on for your Frigidaire refrigerator, model# FGHB2844L. Per the manual, the suggested temperatures should be 37 degrees F for the refrigerator and 0 degrees F for the freezer. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
My frigidaire side by side model#GLHS37EHSB7 is making a constant beeping noise and the electronic temperature display isnt coming on. what could be causing this
Hi Julie, this is JK. Thank you for your recent post!
I see that your Frigidaire Refrigerator, GLHS37EHSB7, is constantly beeping but the electronic temperature display is not working. Generally, this could happen when you experience a power failure. I would strongly suggest that you either unplug or turn the circuit breaker off to the unit for about 30 minutes. Let the unit reset completely and try to use it as normal again. If this concern still continues, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Hope this helps!
Mar 19, 2014 | Frigidaire Refrigerators
I have a frigidaire model glhs37ehsb7, serial # 4a92704953. How old is this refrigerator as I got it second hand
It was produced July 2009. The first digit of the serial number tells the year, 9 = 2009, and the next two numbers describe the week during that year it was produced, 27= Week of July 2-7th, 2009.
Aug 21, 2012 | Frigidaire FRS3R5EMB Side by Side...
Fridge warm, freezer cold. repair guy said its fine if milk is not spoiling. but set at 6 coldest temp is around 40
Can you feel air movement from the freezer to the refrigerator side through the cooling tubes when the evaporator fan is operating?
If not you might have some ice build up in the cooling tube that is not allowing the refregerator to get cold enough. Try a hair dryer to clean it.
Aug 19, 2011 | Frigidaire FRS26R4A Side by Side...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
MAGIC CHEF MCBR1000W
Had trouble finding a diagram with this model # but most common defrost problems are bad defrost thermostat, timer/control board, or a little more rare is the defrost heater.
Oct 06, 2007 | Frigidaire FRT17G4B Top Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
154 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
