Question about GPS
When i put my Navman icn 320 on sometimes it takes upto 30 to 40 minutes waiting for the GPS signal to come through
    Sergeant:
  • 250 Answers
Hello adamant,
In order to determine your current location the GPS needs to receive telemetry information from several GPS satellites. In order to do that it needs a clear view of the sky. This should happen fairly quickly, typically within a few minutes, but depending on how and where you are operating the GPS the process could take significantly longer or the GPS might be unable to aquire a satellite lock at all.
Local geography such as mountains, hills, tall buildings and heavy forest can block the GPS's ability to receive satellite telemetry. The same thing can happen if you are trying to operate the unit indoors or inside of a vehicle without an external antenna. That's why most GPS receivers are installed on the dash board of the car: the windshield and side windows provide it the best view of the sky.
It is also possible that there is a problem with the GPS receiver or the antenna. To test it, try using the device outside in a relatively open area with a clear view of the sky in all directions. It should aquire a satellite fix in about five minutes or less.
Best Regards,
Ken
"Go Ahead. Use Us.
Posted on Jul 08, 2008
My navman icn 520 wont find a gps signal and just keeps waiting for gps
I found that if you open out the receiver at the back and make sure it is touching the windscreen it works for me. If not I don't get a signal. It is worse in one of our cars because it has a heat reflective windscreen.
Feb 05, 2013 | Navman iCN 520 GPS Receiver
My navman icn 320 keeps searching for gps signal
a few things to ensure
1) battery is fully charged
2) Thed correct BAUD rate and PORT are set ( see manual)
3) You are oiutside and there is a clear view of the sky.
Still failing? Then possible damaged SIIRF chip caused by starting engine while plugged into power socket
Please rate my help++++Thanks for using FIXYA
Jul 12, 2010 | Navman iCN 320 GPS Receiver
How can i update my navman icn320
u need to go to the NAVMAN web site, register your GPS and click support and see if any downloads are avil, there may not be any, if not u will have to wait until they are released.
Sep 06, 2009 | Navman iCN 320 GPS Receiver
Can't get updates for ICN 320
I have a ICN 320 Navman and it took 20 to 30 mins to connect to Satalites that is untill yesterday morning when I Updated the Navman Satalite GPS Data if U wish to know what I did please contact me on midniteken@hotmail.com
My ICN 320 now takes a few seconds to conect to Satalite systems/
Regards
Ken
Jun 02, 2008 | Navman iCN 320 GPS Receiver
Navman tcn 320 gps
From the Main Menu press the button underneath the spanner>Demo and deselect the first square if it is ticked>Save.
With your device turned off, press and hold the "OK" button in between the arrows and press the "On" button.
On screen you should see the "Maintenance Menu". Scroll to "GPS menu" using the arrow keys and select it using the "OK" button. Select "Perform a GPS cold start". When this has finished, press the "Home" key twice (the one with the three lines on it). Turn the unit off, then go outside, raise the antenna, and turn it on again. Keep it still for 10-15 minutes and the unit will start to pick up GPS again.
Mar 28, 2008 | Navman iCN 320 GPS Receiver
Misssing SD Card for NavMan iCN 330
I have a 310 and purchased an SD card for France from Navman, it says it works in the 310/320/330 so my guess is that a 320 map will work in a 330.
Jan 24, 2008 | Navman iCN 330 GPS Receiver
Navman icn 320
carefully pull off front grey cover with your thumb, next to card socket, underneath are 4 security screws you need a small torque head screwdriver, take off cover losen security screws inside around battery, unplug and remove battery, replace in reverse.
Jan 03, 2008 | Navman iCN 320 GPS Receiver
Navman icn510 gps reciever problem
How long are you waiting and are you moving while it is trying to acquire signal? These receivers are using older circuitry that may take up to 20 minutes to first acquire a signal from a cold start. If you are moving it may take longer!!! The good news is that after you have initially acquired a location, if you turn the unit off it will only take a minute or so to reacquire after it has "warmed" up.
Oct 22, 2007 | Navman ICN510 GPS Receiver
GPS Logo
132 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
