Question about GE WPRB9220C Top Load Washer
Washer is leaking grease and oil. Can prob be repaired, or do parts need to be replaced?
    Top Expert:
  • GE Master
  • 9,472 Answers
The grease and oil problem you described is from the "tub seal" breaking down. Replace the tub seal and it will correct the problem. Here is a link to the part.
Posted on Jan 01, 2011
What grease or oil do i need to lubricate the bearings and wobble plate on my Karcher pressure washer.
Use a Teflon based grease. Contact an auto parts store to buy it. The grease is usually colored blue.
Jul 16, 2016 | Karcher Garden
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
My K45SS is leaking some kind of oil or grease from the part of the mixer above where the mixer part attaches. It otherwise seems to be functioning fine.
its gear oil from the gear box that the motor turns to make the beaters turn,you need to replace the seals or keep adding food grade oil before you dry out the gearbox and ruin it
Mar 09, 2010 | KitchenAid K45SS Classic Stand Mixer
My classic k45ss leaks oil which drips from the verticle shaft, and my wife says it is making a "funny noise". Maybe it is low on oil, but I turned it on its side to find the model number, and it leaked...
Firstly I would take the head apart to find out what has failed. The oil you see should be a thick grease. Normally it is thick enough not to leak in this way. Has it been repaired and the wrong grease used? If it is making a funny noise it could be that one of the gears has failed. Most parts are easily available. Have a look at the parts list at:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Jan 24, 2010 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid mixer was stored on its side and leaked oil. I don't dare use it now. Can I replace the oil myself? There are no mixer repair centers anywhere near me.
your oil leaking is cause by a bad gasket or the gasket isn't seated properly. you can purchase this gasket but replacing it does require knowledge of the unit. part number for the gasket is 4162324. the grease can be purchased locally at any car parts dealer. generally a thicker paste type grease is used inside these units, but the original part number for the grease is 4160588 and comes in a container with enough grease for 5-8 mixers.hope this helps
Thanks
Oct 06, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Leaking grease
All washer machines have a "transmission" - just like a car these units have oil in them and when the seals that protect the oil from going to our clothes is breake, oil finds its way to your clothes.
Transmission needs to be replaced.
Aug 18, 2009 | GE Profile WPRE6100G Top Load Washer
Hobart mixers A120 & A120T.. has an oil leak. Need Seal kit/repair parts info and type of oil to replace.
You need to take the old grease out and replace it with new and then replace the oil seal
by the way it is messsssssy
Jul 17, 2009 | Hobart A200 Stand Mixer
I have an oil leak on my clothes washer.
If you have a front loading washing machine the oil is really the grease for the bearings that support the drum. The grease seal needs to be replaced, and if you are replacing the seal you might as well do the bearings. This is not a cheap repair because of the amount of labor involved in tearing the machine apart to replace the seal and bearings. If you don't repair the seal, eventually the grease will be washed out of the bearings and the bearings will be destroyed. You can tell if you need new bearings because when the machine is on the fast spin cycle it will sound like a jet engine taking off.
May 24, 2009 | Washing Machines
Oil leak on A200
OK guys, let's try to solve your common problems first then the rest will become clearer.
The Hobart A200,,,,,,,, does not use oil! It uses grease! If you see oil, it's because the grease is separating the oil in the grease. Both machines have not been serviced for at least 5 years. That's about the lenghth of the lifetime of most greases. I recommend that you call Hobart and ask about their tech. rates. All bearings should be checked carefully for wear, as should the worm gear, seal, and the Bronze gear that it turns. The Planetary (mixing part), should be removed as well, cleaned. and inspected. Replace the seal on the planetary and on the mainshaft. Removal of all old grease is required, as it's no longer doing the job it was designed to do, will result in advanced wear, and is the actual source of your problems. The seals were designed to seal grease, not oil.
If Hobart is too pricey for you, and they are for many, try to find someone from a wholesale restaurant equip. place who has rebuilt these machines, or find a repair shop who have experience with this Hobart model. If you'd like to tackle the job yourselves, go to www.hobartservice.com. Register for free, then find the files that match your mixer model and ML # and download the parts files for it. These exploded drawings will be very helpful with your task.
Either way, these mixers need to be opened up to remove existing oil and hardened grease, especially the oil! The planetary must be removed to drain any oil out of it and to regrease it. If you can get the oil out of the mixer, a short fix would then be to simply regrease the the mixer and put it back into service, leaving the existing seals in place. Don't forget to wipe out the shiny ring on the planetary, if it too has oil in it.
There is no seal at the hub. No seals can be tightened. The oil leak underneath the mixer comes from the motor shaft seal at the transmission case where the pinion gear enters the trans., it flows down into the mixer support column and drips onto the floor or counter, again, because of the breakdown of the grease.
If you tackle the job yourself, find your local Chevron Distributor and get several tubes of the approved grease, namely, Chevron FM ALC EP NNGI 2. Chevron p/n 230204-000. If you've found this solution helpful, please rate it as fixya!
Good Luck! ricardok45
Jan 19, 2009 | Hobart A200 Stand Mixer
Grease/oil under washer
Hi, there. Get some one to fix that leak ASAP. The lack of oil will ruin your machine's transmission and/or motor. If you've noticed that your machine runs louder than it used to, then ***stop using it*** until you get the leak repaired. I kept using mine and when it stopped working I couldn't get the parts (a transmission) so I have to get a new one.
Nov 30, 2006 | GE WDSR2080D Top Load Washer
Open Questions:
See all GE WPRB9220C Top Load Washer Questions
GE WPRB9220C Top Load Washer Logo
165 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
