Question about Kenmore 15864/15862 Top Load Washer
Washer doesn't extract water or spin, whats wrong?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Check to see if the motor is running when the washer goes to the spin cycle. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Jan 01, 2011
Washer in the las cycle do not extract the water completely in other words do not spin (hi) to extract the water
You will need to replace the "clutch band" on the washer. The clutch has become worn and will not engage completely to bring the washer up to the proper spin condition. Here is a link to the clutch kit and it comes with the complete instructions for the repair.
Feb 12, 2011 | Whirlpool LSQ9600L Top Load Washer
What is wrong if it is not spinning to extract water?
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 11, 2011 | Maytag MHWZ400T Front Load Washer
Washer will not do Final spin. the time stays on one minent for about 8 mins with no final spin
If the clothes are extracted of water it very well mean your timer needs adjusted slightly, If not, timer needs replaced. Remember, not 100% of your rinse water will be extracted so don't expect it to be hand touch dry when you remove load.But it should not be dripping wet or soaked either
Mar 08, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
What does the max extract feature do
If the washer is removing all of the water from the washer during the spin cycle it is likely working properly. Not an expert but I believe max extract causes the washer to spin for a slightly longer period of time in order to remove more water from the clothes. We use it regularly because our clothes come out to wet otherwise.
May 03, 2009 | Maytag Neptune MAH6500A Front Load Washer
What will the Max Extract button do?
The max extract button will do an extra spin to get any & excess water out of the clothes. It is a good thing to keep on to help cut down on drying time. If you find standing water in the washer, it is possible the hose is NOT in the correct position.
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
