Question about Brother Sewing Machines
I have a brother ult2003d. the fabric will not do thought., the feed dog will not come up to grap the fabric. i change needle ,check the thread. made sure i had the right foot on it, i cleaned the mechine but the feed dog still will not catch the fabric to move it though . could some one help me please
    Genius:
  • 1,788 Answers
Have you checked your manual? It tells on page 1-6 about the feed dog lever, that must be put moved to the right. Now on pg 1-7 it tells you how a adjust your presser foot pressure. You can look at your manual under customer support at www.brother-usa.com. and download it. Then, save it and enlarge the diagrams. You really need to read your manual and familiarize yourself with the different levers and threading. If, the manual does not answer your questions call Brother and see if they have a dvd of this machine to teach you about it. Most stores who sell the this type of machine will teach you all about it, take advantage of it because it looks like a very nice machine and you will have a great time with it after you learn all of the bells and whistles. Good luck and Happy New Year.
Posted on Jan 01, 2011
Why does the fabric get stuck in the feed dog plate?
try changing the needle it could be blunt
also make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin are for lint
Mar 24, 2016 | Brother Se425 Computerized Embroidery &...
My machine doesn't sew. When I start sewing it seems like the material isn't moving but at the same time I see that the threads haven't connected.
check for broken drive belt that works the bottom shaft in the machine
have a sewing machine service center service it
Nov 07, 2015 | Brother Sewing Machines
Brother Innovis 1e isn't stitching properly when the feed dogs are down
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Nov 25, 2013 | Brother Sewing Machines
On my brother ult2003d I can't get it to sew two stitches before it bird nests appear under the needle. changed needle, threads, blew it out, nothing seems to help. flashes up on screen that safety device...
try these suggestions first
make sure top thread has not come off thread take up lever
try a new needle--make sure it's the right one for the fabric being sewed--make sure the needle is inserted correctly up into the needle holder
make sure the bobbin is turned the correct way in the bobbin case
if none of these suggestions help
it's possible that the timing could be off, it would be a good idea to have the machine checked
Oct 23, 2013 | Brother Sewing Machines
Brother pacesetter ULT2003D
try using a different spool of thead on the top and bobbin
also try changing the needle
and if these suggestions don't help then call the repair shop and check
with them about the machine not sewing light fabric
Jan 04, 2013 | Brother PE770 Computerized Sewing Machine
Everytime i try to sew the bobbin sounds loose and the stitches are knotted and tangled
Hello
The feed dogs should be in the highest position for regular sewing. If the feed dogs are not raised above the plate it will do this. With the machine unthreaded and no fabric.. run the machine to see if the feed dogs are moving and are working.
.Always make sure you have about 3 inches of both threads before taking any stitches, and both threads are positioned directly behind the needle.
make sure you re-thread it exactly as the owners manual shows.
Change the needle
Change the thread
Take it in for servicing
Jul 22, 2011 | Brother Sewing Machines
Have a janome master craft 3000, just bought it used yesterday. Was sewing fine then all of a sudden it would stop pushing the material through like the needle was dull or something. Now it's doing it...
First do a process of elemination. Unthread the machine, both top and bottom, take out the needle. Place a piece of fabric under the pressure foot, lower the pressure, and depress the foot control. Does the fabric feed? If it does, then put in a NEW needle, thread up the machine, and see what happens. A dull needle won't prevent the fabric from feeding. If the fabric does not feed with no thread, then you have a pressure foot pressure problem, or a feed dog height problem, or a feed step motor problem, or possibly a board problem. If it only has a problem when you thread it up, then maybe you have a burr on the needle plate and the thread is hanging up on it and preventing the fabric from feeding. Check for all of these and if you still need assistance respond back.
Apr 27, 2011 | Janome Memory Craft 3000
Its sews fine for a while and then the thread gets stuck in the parts around the bobbin. I've removed the bobbin parts and cleaned and it still does it.
change the needle
also make sure the needle is right one for the fabric & thread
clean under the needle plate where the feed dogs are for lint
check to see if the thread has come off the thread take lever
Nov 21, 2010 | Brother XL-3030 Electronic Sewing Machine
Presser foot will not feed and the thread wont catch
The presser foot is not suppose to feed. It's purpose is to hold the fabric in place as the feed dogs feed the fabric from the front to the back of the machine as stitches are formed.
Check the needle to be sure it is installed with the flat side of the needle shank facing the back of the sewing machine.
Refer to your manual to be sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the guides.
Pull the bobbin thread up by lowering the threaded needed down and then back up. Pull both threads under the presser foot and to the back of the machine.
Set the stitch length to 2.
Place a scrap of fabric under the presser foot. Holding onto the ends of both threads, lower the needle into the fabric for the first stitch.
If the machine still does not stitch, the machine may need to go in for maintenance as the timing may need to be adjusted.
If the feed dogs are not moving, this also needs to be repaired by sewing machine service tech.
Mar 29, 2010 | Brother LS-2125 Mechanical Sewing Machine
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
62 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
