Question about Carrera Go!!! Nascar Electric Race Set
My one car on one side of the track for 4 track lengths wont run,
    Sergeant:
    Champion:
  • 226 Answers
It not geting power to that track. check the stip in the track.
Posted on Jan 01, 2011
How heavy should the hammer throw be in both mens and womens hammer throwing competitions?
The men's hammer weighs 7.257 kilograms and is 4 feet in length and the women's hammer weighs 8.82 pounds and is also 4 feet in length.
Jan 17, 2013 | Sport & Outdoor - Others
2004 jeep grand cherokee rear window is off track
Forget it. You've got a broken window regulator. Have to replace the entire unit.
Replace window regulator Ricks Free Auto Repair Advice
Feb 17, 2018 | 2004 Jeep Grand Cherokee
I have 2003 toyota 4 runner and my moon-roof will not close, when i press and hold the button the motor sounds like its working but it wont slide, one side starts to move but the other side wont move, i...
You may be right but the most common problem is a little arm for the track that breaks and is not repairable, there are not any parts for the track except like the motor that can be replaced, every one that i have ever checked needed a new track, this is so common and kinda of a big job the inside roof needs to be removed to gain access to track.the best thing would be to try and check prices for the track at dealer the glass can be reused you would just need the track, you could also check junk yards but if its not much more for new i wouldgo with the new one, hope this is helpful.
Mar 05, 2011 | Toyota 4Runner Cars & Trucks
I need a spacewarp 5000 english instruction manual
I think everything up to step 12 should be pretty self explanatory.
Steps 13 and up are below
13 - Initial ramp
Cut two pieces of wire into 150 cm (59 inches) lengths (may need to be trimmed down once put on track)
Connect one end of each piece to J-3 then thread through the following order
G-7, D-4, C-5, F-6, H-4, I-4
Connect to track separator piece (the piece with the flipper)
14 - Track A (Loop)
Cut two pieces of 270 cm (106 inches) lengths (again, may need to be trimmed down once put on track)
Connect one end to the side nearest G then thread through the following order
E-3, D-1, D-2, C-1, C-2, A-1, B-1, E-2, G-2, I-1, H-1, F-1, E-1, G-1, J-1
Nov 13, 2010 | Bandai Toys
Nordic Track C2000 starts and then stops.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 21, 2010 | Exercise & Fitness
Rear glass goes up or down, but only after truck drives or runs for about 15 minutes. shut truck off and wont work till drive or run for about 15 minutes. 87 4 runner
chk your battery voltage before you drive and after. The window motor is probabaly drawing more current for some reason. and needs the voltage available after a short charge. May be too much resistance in window guides. Lubricacate everything you can with silicone spray includeinf the side guides/tracks. Good Luck, Ned
Oct 04, 2009 | Toyota 4Runner Cars & Trucks
I have a 93 linciln town car all 4 off my power windows wont work
If you here the window motors running then take off the inner door panel and make sure the window gear is engaged into the motor. If so and the track moves up and down then the window came out of the track holders and has to be glued back in it.
May 12, 2009 | 1993 Lincoln Town Car
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Carrera Go!!! Nascar Electric Race Set Logo
198 people viewed this question
Top Carrera Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Carrera Toy Expert? Answer questions, earn points and help others
